106 Pages «<4243444546>»
Sticky Wickett
#861 Posted : 22 June 2017 21:25:05
Hull supports.
Sticky Wickett
#862 Posted : 22 June 2017 21:25:53
Further hull supports added.
Sticky Wickett
#863 Posted : 22 June 2017 21:28:54
Yet further supports added. These were all fitted by using a small piece of 0.5mm plastic sheet to represent the hull as guide. From there i could make each support the correct depth to maintain the hull curvature.
Sticky Wickett
#864 Posted : 22 June 2017 21:31:35
Another view showing the supports, placed to maintain curvature, for when the rear pressure hull is fitted.
Sticky Wickett
#865 Posted : 22 June 2017 21:32:49
Nearing completion of fitting the hull supports.
Sticky Wickett
#866 Posted : 22 June 2017 21:35:23
A one off piece to be fitted on the inside of the saddle tank, providing support for the rear inner pressure hull.
Sticky Wickett
#867 Posted : 22 June 2017 21:36:00
Piece fitted.
Sticky Wickett
#868 Posted : 22 June 2017 21:43:30
At this stage i had been continuously test fitting a 0,5mm thick sheet, which mimicked the hull, to check that it would have the correct, round profile when fitted to the supports. Once i was happy, i went back to the hatch and concentrated on fitting this prior to fixing the inner pressure hull.
I had to fabricate sides for the hatch so that i could use their edge as a guide when aligning it to the hull supports, otherwise it might sit too proud and the hull supports are redundant or too low and there would be a gap between it and the hull.
This photo shows the sides being added to the hatch.
Sticky Wickett
#869 Posted : 22 June 2017 21:44:26
Fabricated sides.
Sticky Wickett
#870 Posted : 22 June 2017 21:45:30
The hatch sides filed to the correct profile.
Sticky Wickett
#871 Posted : 22 June 2017 21:46:23
From another angle.
Sticky Wickett
#872 Posted : 22 June 2017 21:48:09
This photo shows how the side pieces connect up the front and rear of the hatch mouth, giving the correct profile.
Sticky Wickett
#873 Posted : 22 June 2017 21:49:55
Torpedo loading hatch correctly located. The side pieces were aligned with the hull supports so that i knew the hull would sit properly.
Sticky Wickett
#874 Posted : 22 June 2017 21:51:06
Close up of the torpedo loading hatch.
Sticky Wickett
#875 Posted : 22 June 2017 21:52:10
You can see how useful those side pieces were in aligning the hatch well.
Sticky Wickett
#876 Posted : 22 June 2017 21:53:20
Torpedo loading hatch and well glued in place.
Sticky Wickett
#877 Posted : 22 June 2017 21:54:38
The attached photo shows the rear inner pressure hull cut to shape. Similarly to the front section, this also took several attempts to get right.
Sticky Wickett
#878 Posted : 22 June 2017 21:55:26
Rear, inner pressure hull fitted.
Sticky Wickett
#879 Posted : 22 June 2017 21:58:54
Another view showing the completed inner pressure hull. I still have to trim, file, apply filler and further file on all these sections, but so far i'm very happy with the way it has turned out. At times progress was very slow, especially during the hot evenings when it felt like i had achieved very little.
In the attached photo you can see the recessed torpedo loading hatch.
Sticky Wickett
#880 Posted : 22 June 2017 22:01:06
Another view showing the recessed hatch well.
This page was generated in 0.613 seconds.
