Another view of the new section. Not a bad job at all! Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Once that was done I test fitted the deck and also the torpedo tubes to check for clearance. All looking good!  The Torpedo Compartment is now ready for undercoating! All the compartments are now paint ready but before I can start on that there are some other smaller jobs to be done externally on the hull. Starting from the bow and working aft I will over the next two weeks add any part-works supplied parts, carry out running repairs and scratch build any items in readiness for adding the weld lines and rivets. First job was to carry out some running repairs at the bow section. Three different sections of brass strip rivets had partially lifted away due to handling and required a spot of glue to remake the bond. The attached photo shows one of the brass strip rivets. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Once I was happy the rivet strips were all laying flat I then proceeded to look at the part-works supplied brass strips that run along the port and starboard sides near the bow. The attached photo shows one of the brass strips fitted to the starboard side. It took a few attempts as there is twist to the hull and the strip wouldn't adhere as it flexed too much. My method was to hold it in place with one hand and run a bead of glue along it's edges in small sections ensuring it adhered properly all the way along. It might still add 1.0mm aluminium pins along it's length at some point to make sure it doesn't come away. That will be a job for later. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Another view of the same brass strip. I had to file a contour on the one end to match the profile of the hull. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The next brass strip fitted, shaped at one end to align with the anchor well. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Another view of the brass strips so far fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The final piece fitted to the starboard side of the bow. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The same technique was applied to the port side. The attached photo shows all brass strips fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
A close up of the bow, port side. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Port side brass strips complete. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Well that's it for this weeks update, more posts to follow next Thursday. Thanks for looking in, have a great weekend and happy modelling. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Hi Phil you`re updates are great  love all the work you`ve put in so far  looking forward to the paint  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Another excellent update Phil, really loving all of the extra scratchbuilt parts that you are adding to this model and it will certainly pay you back with big dividends in the way the completed model looks - very well done, looking forward to next Thursday already!!
Kev
Another great update Phil. Looking really good.
tigerace wrote:Hi Phil you`re updates are great  love all the work you`ve put in so far  looking forward to the paint  regards Phil Thanks for your kind comments Phil!  Bring on the paint! Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
pemberg wrote:Another great update Phil. Looking really good.
Graeme Thank you very Graeme.  I'm glad you like the updates. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,280 Points: 22,147 Location: Northamptonshire, England
Excellent work as usual Phil. Mark Regards Markwarren (Mark) Admin
Another fantastic and enjoyable update Phil. All the extra work and detailing is really going to pay off, cant wait to see it under some point
Just collected the final issue of this but no idea when I will get around to it. When I do I will be using your build for guidance, nice work so far Al
Guest (15)
