Next step were the fenders. I wanted to make them a little bit more descreet than the instructions suggest - also i wanted no gaps to the hull. So i had to adjust some of the wriggles that were in the way. Used 2x1mm walnut fo the finish.
As often i was like - oh well i`ll just quickly make those fenders - which then turned out to be a 4h-job!!
Who needs sleep anyway? :)DaDokta attached the following image(s): Greetings, Walter
Hi Walter, The ladders and entrance looks fantastic. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Hi Walter.  looking fantastic. well done. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Lovely work work, Walter. Those lines are just about perfect.
Thanks guys!
Again a small update as i completed all the fenders. Again i deviated from the instructions regarding the front fenders and built them more straight and not running along the curve of the hull.DaDokta attached the following image(s): Greetings, Walter
Yes, you're right, they should be straight. I wonder why they did it that way.
Nice work as ever.
Hi walter. looking very nice. well done. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks guys!
I was informed that with the start of the new forum sometimes in fall - threads with those damn photobucket-icons instead of the pics will be deleted.
So this is also a heads-up for all of you who are also hit by the PB-issue!
To prevent the deletion i edited all my former posts in this thread and uploaded the pics directly.
As you can imagine this was a pain in the ass to do - and i only re-uploaded the most important pics.
But it`s done after all - and i hope there will never occur a problem regarding the pics any more!
Also i wanted to remind you that with the link in my signature you can see all the pics i ever made of this build.
OK guys! Now for my other threads! Greetings, Walter
Hi guys!
The wood for the cap strips finally arrived - so i gave it a go.
I started with the forcastle. As mentioned before i wanted the cap-strips to follow the curve of the hull (other than in the instructions)- also i used 8x1mm strips of pear-wood, as i want to achieve a more slim look.
Wasn`t easy to bend those strips but with hot water and a soldering iron i finally succeeded!
The painting will be finished after all the cap strips are mounted.DaDokta attached the following image(s): Greetings, Walter
Lovely work Walter, all looking great.... Regards Alan
I finnished all the cap strips ( all with 8x1mm strips).
I´m especially pleased with the stern - as i could achieve the look of the orignial as i planned.DaDokta attached the following image(s): Greetings, Walter
Another very nice update Walter, looks great.... Regards Alan
Thanks Alan!
Next i used 2x1mm walnut for the moulding-strips and some pear-wood for the carvings - which i produced in different sizes.DaDokta attached the following image(s): Greetings, Walter
I also realized that the anchor supports were missing in the instructions. So i scracht-built them.DaDokta attached the following image(s): Greetings, Walter
Loving your mods and improvments, a qulity build “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Thanks Jase!
This is what she looks like after painting the hull and the cap strips ( i taped the areas for the chainwales).DaDokta attached the following image(s): Greetings, Walter
Great looking progress Walter, very nicely done.... Regards Alan
Thanks Alan! Next up was the beakhead bulkhead.
Because of the my modifications to the forecastle bulwarks my beakhead bulkhead was about 1 cm less high than in the instructions - so again i had to modify the parts.
Also i used 3D-printed parts for the decorations.DaDokta attached the following image(s): Greetings, Walter
Very nice, love the detail. Mark Regards Markwarren (Mark) Admin
Thanks Mark!
I built the first gratings - used 1x1mm strips.DaDokta attached the following image(s): Greetings, Walter
Guest (14)
