 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,711 Points: 17,285 Location: ipswich
Hello there Keith.
The springs were a real pain. Each leaf was very 'springy' and extremely stiff. Not only that, but for some odd reason they varied in the springy-ness department so that it was an added difficulty getting the curve the same all the time.
I literally rolled each leaf around a piece of 40mm tube. The curve was WAY more than required, but the parts sprung back to almost straight. After half a dozen goes at that with little effect, I resorted to using pliers, and bending each leaf at 10mm intervals whilst trying not to get a crease. The shorter the leaf, the tougher it became.
The end result wasn't perfect, but they all fitted together fairly well. I contemplated wrapping the springs in cord but I like the look of the leaves in the blackened steel they came as.
Making some great progress on this Roy  never knew that the early Bugatti's had the gears fitted, you always learn something knew on this forum. Al
 Rank: Semi-Pro Level 2 Groups: Registered
Joined: 17/01/2016 Posts: 96 Points: 292 Location: United Kingdom
roymattblack wrote:Hello there Keith.
The end result wasn't perfect, but they all fitted together fairly well. I contemplated wrapping the springs in cord but I like the look of the leaves in the blackened steel they came as. Thanks Roy, sounds like fun..... Keith.
Great update Roy  the engine looks superb  and those springs are outstanding  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Rank: Vice-Master       Groups: Registered
Joined: 07/01/2015 Posts: 856 Points: 2,479 Location: Sevenoaks, UK
I wonder if it would be possible to anneal them... basically you heat up over the flame, then leave to cool down slowly. They should become much easier to shape. Then you should be able to bring back the springiness at least to some point by heating up again and cooling them down immediately by submerging into cold water. Any images I post on my personal builds are free to be used and shared under Creative Commons Attribution license, which means you can do what you want with them, on the condition you mention I'm the author.
Happy building :-) http://www.model-space.com/gb/
Hello chaps. Apologies for the slow updates but it is, after all, Summer - even if it isn't great. Most evenings will find me sitting in the garden with a glass of plonk so little model-bashing is going on. Daytime, I'm playing with my 1:1 toy car... However, the front springs, uprights and assorted gubbins are now assembled and fitted. Nothing overly complex here so not really much to say other than it's a fun build. I'm considering putting the whole thing to bed for a few months as for me, Autumn/Winter/Spring is model time. Roy. roymattblack attached the following image(s):
Looks good with the engine in Roy Al
Coming along very nicely Roy.
Best regards
Keith
Very impressive. Nice work Roy.
looks great Roy  looking forward to you restarting this  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
More superlative work roy Ken's the name modeling's the game.
Very nice progress indeed Roy
