106 Pages «<4849505152>»
Sticky Wickett
#981 Posted : 20 July 2017 08:28:41
1st discharge port fitted with the new plastic flange.
Sticky Wickett
#982 Posted : 20 July 2017 08:29:30
2nd discharge port fitted with the new plastic flange.
Sticky Wickett
#983 Posted : 20 July 2017 08:30:42
3rd discharge port fitted with the new plastic flange.
Sticky Wickett
#984 Posted : 20 July 2017 08:34:57
Well that's it for this weeks update. Next weeks update will see me continue aft along the boat finishing off all of those small jobs.
I have also ordered paint and the rivets and weld lines.BigGrin
Thanks for looking in, have a great weekend and happy modelling.Cool
Phil W.
kpnuts
#985 Posted : 21 July 2017 11:59:04
Superb modeling
Sticky Wickett
#986 Posted : 21 July 2017 16:23:44
kpnuts wrote:
Superb modeling
Thanks Ken.Cool Your comments are much appreciated!BigGrin
Phil W.
#987 Posted : 21 July 2017 23:00:08
Always enjoy looking in on this build and love the detailing you're applying.....looks fab....Drool Drool
Sticky Wickett
#988 Posted : 24 July 2017 09:17:39
Thank you for looking in Alan.Cool Your comments are always appreciated.BigGrin
Phil W.
#989 Posted : 24 July 2017 09:34:32
Some more great scratchbuilt detail from you Phil, this really is going to be an exceptional model when it's finished - very well done! Cool Drool ThumpUp
Sticky Wickett
#990 Posted : 24 July 2017 10:18:00
Thanks for looking and your encouraging comments Kev!Cool
Lots more to do, so stay tuned for another update later this week.
Phil W.
Sticky Wickett
#991 Posted : 27 July 2017 07:37:13
Good morning from 'The Dockyard'.
Well the paint has arrived and i'm waiting for my order of rivets and weld lines to arrive from the U.S. Before these can be applied however, i still have a few more odd jobs to complete.
This weeks update on my U230 U-boat build log will be looking at making a profile to blank off the area just aft of the aft torpedo compartment, fitting part-works supplied etched brass strip to the stern and fitting the rudder mount.
First job was to fabricate, from 0.5mm thick plastic sheet, a triangular shaped piece to blank of the gap between the outside hull and the tapered inner pressure hull. See attached photo.
Sticky Wickett
#992 Posted : 27 July 2017 07:38:33
The triangular shaped piece being test fitted.
Sticky Wickett
#993 Posted : 27 July 2017 07:39:50
After much filing so that it would wedge itself in place, it was secured with glue. The attached photo shows it completed and in situ.
Sticky Wickett
#994 Posted : 27 July 2017 07:42:40
Next up was to make a scalloped piece, again from 0.5mm thick plastic, using the same technique i used for the other compartments, to blank of the gap between the outer and inner hulls.
The attached photo shows the first piece being filed to suit.
Sticky Wickett
#995 Posted : 27 July 2017 07:44:12
The profile was then marked out for the inner cut. The attached photo shows it ready for cutting.
Sticky Wickett
#996 Posted : 27 July 2017 07:45:07
Internal section removed.
Sticky Wickett
#997 Posted : 27 July 2017 07:47:59
I then glued a backing piece to it giving the impression of a recess, similar to previous compartment profiles, filed it to suit then fitted the completed piece to the boat.
The attached photo shows the scalloped, blanking piece completed.
Sticky Wickett
#998 Posted : 27 July 2017 07:52:51
Moving on, the next job was to fix the part-works supplied brass strips to the stern. Using the same technique as for the bow section; sanding the underside to act as a key for the glue, filing the ends to suit the hull profiles and finally drilling and pinning with 1.0mm aluminium tube to securely fasten the strips.
The attached photo shows the first of the strips fitted prior to pinning.
Sticky Wickett
#999 Posted : 27 July 2017 07:53:48
Second strip fitted and cut to allow for the exhaust plate.
Sticky Wickett
#1000 Posted : 27 July 2017 07:55:33
Third strip on the port side fitted. Again, filed to suit the exhaust plate profile.
Guest (10)
This page was generated in 3.609 seconds.
