16 Pages «<1112131415>»
Eaglemoss Delorean Options
spike
#241 Posted : 20 July 2017 17:34:45
Issue 24
Parts -
8x Pulleys (different sizes)
Alternator Fan
A/C Compressor Belt
Alternator Belt
3x AP Screws
1 AM Screw
spike attached the following image(s):
Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
spike
#242 Posted : 20 July 2017 17:54:07
Place the first pulley onto the post at the bottom of the rear of the engine. Place the second pulley on the same post up against the first. Then place a third pulley onto the same post and secure all 3 with an AM screw.
Thanks for looking.
Duane
spike
#243 Posted : 20 July 2017 19:29:24
Place the forth pulley onto the post above the other pulleys. Then place the second cone shaped pulley onto the same post against the first pulley and add an AP screw.
Thanks for looking.
Duane
spike
#244 Posted : 20 July 2017 19:33:53
Place thee alternator fan onto the post at the rear of the alternator then place a pulley up against the alternator fan and secure with a AP screw.
Thanks for looking.
Duane
spike
#245 Posted : 20 July 2017 19:39:10
Combine the last to pulleys, place the A/C pulley assembly onto the rear or the A/C compressor and secure with an AP screw.
Thanks for looking.
Duane
spike
#246 Posted : 20 July 2017 19:41:38
Place the alternator belt in the recesses of the 3 pulleys. Then place the A/C belt over the 2 recesses in the pulleys.
Thanks for looking.
Duane
#247 Posted : 20 July 2017 19:44:59
Nice work and not a bad looking engine. I'm itching to see some of the body panels
spike
#248 Posted : 20 July 2017 20:04:33
Yes i can't wait see how the body panels turn out. So far the parts are good quality. The engine is nice and detailed be good if EM did a model of the engine like they did with the Nissan GTR.
Thanks for looking.
Duane
spike
#249 Posted : 20 July 2017 20:09:39
Issue 25
Parts -
Bracket (Right)
Bracket (Left)
Bracket (Front)
Exhaust Front Pipe (Right)
Exhaust Front Pipe (Left)
4x AM screws
2x NM screws
3x AP screws
Thanks for looking.
Duane
spike
#250 Posted : 20 July 2017 20:21:09
Fit the bracket (right) up against the right side of the engine and add 2 AM screws.
Thanks for looking.
Duane
spike
#251 Posted : 20 July 2017 20:25:11
Fit bracket (left) on the left side of the engine and add 2 AM screws.
Thanks for looking.
Duane
spike
#252 Posted : 20 July 2017 20:31:13
Align the holes on the bracket (front) with the holes on the left and right brackets and secure with 2 NM screws.
Thanks for looking.
Duane
spike
#253 Posted : 20 July 2017 20:44:21
Join the 2 exhaust pipes together and add an AP screw. Place the exhaust front pipe assembly over the transmission case, fixing the right side to the exhaust manifold with an AP screw. Then fix the left side of the pipe to the left side exhaust manifold with an AP screw.
Thanks for looking.
Duane
#254 Posted : 20 July 2017 20:58:53
Nice work Cool a lot of detail in that engine.
spike
#255 Posted : 20 July 2017 22:36:05
Issue 26
Parts -
Silencer Bar
Silencer Front
Exhaust Pipes
Connector
Connector Left
Connector Right
Boots
1x AM Screw
3x DM Screws
5x AP Screws
2x EP Screws
2x FP Screws
Thanks for looking.
Duane
spike
#256 Posted : 20 July 2017 22:56:48
Insert 1 of the exhaust pipes into the side of the silencer rear and secure with an AP screw. Do the same with the other exhaust pipe on the other side of the silencer rear. Place the silencer front on top of the silencer rear and add 2 FP screws.
Thanks for looking.
Duane
spike
#257 Posted : 20 July 2017 23:24:28
Fit the silencer to the rear of the engine, inserting the exhaust pipe into the corresponding hole. Secure the left side of the silencer to the engine with an AP screw. Secure the right side of the silencer to the engine with an AM screw. Insert the pins on the connector into the hole on the silencer and the hole above.
Thanks for looking.
Duane
spike
#258 Posted : 20 July 2017 23:38:15
Place the engine into the chassis frame. Turn the assembly over and secure with 3 DM screws.
Thanks for looking.
Duane
spike
#259 Posted : 21 July 2017 00:00:21
Pass the boot along to the centre of the left track rod (from issue 12). Fit the track rod onto the wheel hub and secure the other end to the axle mount with an EP screw. Slide the boot along the rod covering the connection between the track rod and the axle. Do the same with the right track rod on the right side.
Thanks for looking.
Duane
spike
#260 Posted : 21 July 2017 15:19:53
Secure the left bracket to the silencer with an AP screw. Then do the same for the right bracket on the right side.
Thanks for looking.
Duane
This page was generated in 0.393 seconds.
