4 Pages <1234>
Tamiya RC Truck (Knight Hauler) Options
spike
#21 Posted : 25 July 2017 17:50:18
tigerace wrote:
Result spikeBigGrin hope the colour turns out just as you want it too BigGrin quite detailed and largeDrool Drool can`t wait for moreDrool regards PhilCool
Thanks Phil this is my first time using spray paint Bored so not sure how its going turn out as last time i used spray paint i put to much on in some places and in others not so much.
Duane
Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
spike
#22 Posted : 25 July 2017 18:52:17
Got the cab painted don't look to bad saying its my first time spraying. I will get the seats and dash painted, the bash will be grey and i will do the seats tan. I will put some LEDs at the back of the dash to light up the panel and connect them to the mfu when i get it, the dash lights will come on when the head lights turn on.
spike attached the following image(s):
Thanks for looking.
Duane
#23 Posted : 25 July 2017 19:41:10
BigGrin Looking good with the paintCool
spike
#24 Posted : 25 July 2017 19:48:31
I have put the first coat of paint on the seat to see how it looks and i think i will go ahead with the colour. I have also picked up a bruder figure to go inside the truck.
Thanks for looking.
Duane
spike
#25 Posted : 25 July 2017 19:52:53
Thanks arpurchase i have got tiny hairs under the paint and there making it look a mess. I need try and sort it out maybe sand down the areas and respray. I will get a spray booth built before i do any more spraying.
Thanks for looking.
Duane
#26 Posted : 25 July 2017 20:19:27
Like the colour Spike, and a nice Bruder figure as well.
AL
#27 Posted : 25 July 2017 21:05:44
Try wet sanding when you sand it then just build up very light coats
spike
#28 Posted : 25 July 2017 23:53:10
AL
Thanks Spal, i didn't think the colour would of been that good as on the pictures it looks more black then blue. The glitter mixed with the blue stands out and after a clear coat goes on the glitter will shine.
Thanks for looking.
Duane
spike
#29 Posted : 25 July 2017 23:58:06
Thanks for the tip i will give that a try.
Thanks for looking.
Duane
spike
#30 Posted : 26 July 2017 00:06:41
I will start the build and add the extras later on. The chassis has been put together apart from the servos and servo mounts.
Thanks for looking.
Duane
spike
#31 Posted : 27 July 2017 17:03:19
I got my RC pack this morning so i have added the servos. I have put the dampers together and fitted them to the chassis. All the leaf springs are fitted to the chassis. i will be upgrading the dampers later on.
Thanks for looking.
Duane
spike
#32 Posted : 27 July 2017 17:15:57
I put an LED strip light at the back of the dash to see how it looks. The dash has been painted and ready to go in the cab. I will sand the cab down and respray it.
Thanks for looking.
Duane
#33 Posted : 27 July 2017 19:33:01
BigGrin Going together well and nice workCool
#34 Posted : 27 July 2017 19:43:58
Nice work Spike BigGrin like the lit up clocks.
spike
#35 Posted : 28 July 2017 09:57:55
Thanks for looking arpurchase BigGrin
Thanks for looking.
Duane
spike
#36 Posted : 28 July 2017 10:00:33
Thanks Spal i may try and light up the other dials but the plastic is a lot thicker.
Thanks for looking.
Duane
spike
#37 Posted : 28 July 2017 10:09:19
Fixing together the differential housings. The E rings are very tricky with them being so small.
Thanks for looking.
Duane
spike
#38 Posted : 28 July 2017 10:14:23
Next the back axles and dampers are fitted to the chassis.
Thanks for looking.
Duane
spike
#39 Posted : 28 July 2017 10:20:53
The step plates go on and connect to the chassis. The the fuel tanks and tool boxes are built and added to the step plate.
Thanks for looking.
Duane
spike
#40 Posted : 28 July 2017 10:27:32
The gears and motor are put together and then placed into the gear box housing then added to the chassis with the propeller shaft.
Thanks for looking.
Duane
4 Pages <1234>
This page was generated in 0.492 seconds.
