Joined: 29/03/2010 Posts: 202 Points: 569 Location: sunderland
Has anyone else been short changed with the length of 2x2mm strip for the hatches, I was finishing the second hatch when I ran out of 2x2, (about 1.5" short) non was wasted so I was looking for another length as there has always been spare strips for all the other jobs, looking through the 'mag' I see only one length was issued. Not a big problem, which was sorted by plaining a wider strip to size, just a bit miffed about having to spend time to do this. Hope it's just a 'one off'! Jeff
Joined: 30/01/2011 Posts: 865 Points: 2,410 Location: Cambs
I seemed short of 2mm x 2mm, but had some spare wood lying around so was ok, I thought at first I had misplaced some, as I have stained mine and had put the supplied wood aside to dry. Come on you Jimmies
Joined: 21/03/2010 Posts: 270 Points: 837 Location: Nr. Dartford,
Hi Jeff, Did you not get 2 lengths of 2x2mm? Sure you haven't misplaced 1. I think there was 1 with each set of hatch parts over 2 issues. I dropped pack 45 under the bench when I was doing the deck beams and thought the worst. Found it later after the panic had subsided I'm sure Admin will sort you out if you are short. Laury
No Tarbrush, as mentioned earlier I have accumulated a lot of spare strips of various sizes but not 2x2. I've been through the mags to check and only one was sent, it's now sorted but like you have stained and only noticed the shortage when assembling, only a little time wasted but I hope it's the only time 'DeAgo' miscalculates measurements!
Jeff
Sorry Tarbrush, it was Bob that stained!!
Jeff
jeff averre wrote:Sorry Tarbrush, it was Bob that stained!!
Jeff Yup, thats me, if it moves stain it, if it doesn't stain it anyway Come on you Jimmies
