106 Pages «<4950515253>»
Sticky Wickett
#1001 Posted : 27 July 2017 07:56:56
Fourth and final brass strip fitted to the port side of the stern.
#1002 Posted : 27 July 2017 08:16:08
Very nice progress, looks good.....Drool Drool
Sticky Wickett
#1003 Posted : 27 July 2017 08:17:15
First strip fitted to the starboard side.
Sticky Wickett
#1004 Posted : 27 July 2017 08:19:02
I continued in this fashion for the remainder on the starboard side.
The attached photo shows the final strip fitted.
Sticky Wickett
#1005 Posted : 27 July 2017 08:21:16
Thank you Alan. Cool BigGrin
Phil.
Sticky Wickett
#1006 Posted : 27 July 2017 08:22:26
An angled shot showing all starboard strips in place.
Sticky Wickett
#1007 Posted : 27 July 2017 08:23:30
Starboard side view showing the U-boat so far.
Sticky Wickett
#1008 Posted : 27 July 2017 08:27:15
Moving on, the next job was to fit the rudder mount. In the photo you can see when it was dry fitted that there's a gap around the edges. Rather than fill these i opted to make a plastic spacer on the front section to aid fixing when glued.
Sticky Wickett
#1009 Posted : 27 July 2017 08:28:04
This photo shows the plastic spacer fitted to rudder mount.
Sticky Wickett
#1010 Posted : 27 July 2017 08:29:24
Rudder mount being test fitted with spacer.
Sticky Wickett
#1011 Posted : 27 July 2017 08:34:32
Once i was happy with the fit, the next task was to drill through the body to accept a 2.0mm diameter brass rod. The rudder mount, even when glued, could be easily knocked off so pinning parts like this makes them phenomenally strong. I have used this technique throughout my build on all the major components.
The attached photo shows the hole drilled and the brass rod being test fitted to check for clearance.
Sticky Wickett
#1012 Posted : 27 July 2017 08:36:03
I then withdrew the rod and fixed the mount with pva to the hull. I used clips to ensure it aligned correctly.
Sticky Wickett
#1013 Posted : 27 July 2017 08:38:57
Once the pva was set after 24hrs, i back filled any gaps with superglue. From then i could confidently drill through the rest of the hull to accept the brass dowel.
The attached photo shows the mount fixed in place.
Sticky Wickett
#1014 Posted : 27 July 2017 08:40:23
This photo shows the dowel being inserted to check for clearance prior to it being cut to length,
Sticky Wickett
#1015 Posted : 27 July 2017 08:42:15
I glued the dowel in place and left to set. It's now very strong and robust.
Once all was dry i then filled any gaps.
Sticky Wickett
#1016 Posted : 27 July 2017 08:42:53
All filler sanded smooth.
Sticky Wickett
#1017 Posted : 27 July 2017 08:43:31
Rudder mount completed.
Sticky Wickett
#1018 Posted : 27 July 2017 08:45:20
Well that's it for this week. More updates to follow next week.
Thanks for looking in, have a great weekend and happy modelling.BigGrin
Phil W.
#1019 Posted : 27 July 2017 09:33:38
looking fantastic
Sticky Wickett
#1020 Posted : 27 July 2017 09:53:38
jase wrote:
looking fantastic
Cool Thanks Jase!BigGrin
Phil W.
This page was generated in 3.849 seconds.
