12 Pages «<23456>»
Pete's R2 build Options
Ritchie69
#61 Posted : 26 July 2017 20:19:21
Issue 28
Now to secure the wheel in place. Another bearing and the wheel frame/support for the other side.
Ritchie69 attached the following image(s):
Completed - R2D2
#62 Posted : 26 July 2017 20:49:10
Coming together nicely, great job.
#63 Posted : 26 July 2017 20:58:53
Lovely progress Ritchie ThumpUp
#64 Posted : 28 July 2017 11:26:42
Nice update Peter. It really starts to have some weight about it now.
Metal Mech
#65 Posted : 28 July 2017 11:57:44
That's one sexy leg right there.
DeAgostini kit builds:
Shelby GT-500: 28% Complete
Coser
#66 Posted : 28 July 2017 15:22:30
But the sexiest of legs are covered in black!
[I might even be able to show you one in a couple of weeks.]
LOL
Current Builds
Hachette: T800 Endoskeleton
Finished Builds
#67 Posted : 28 July 2017 17:00:56
BigGrin Looking goodCool
Ritchie69
#68 Posted : 28 July 2017 19:33:07
Thanks all.
The start of the build started slow, as nothing much to do each month. Now there is more to do each month.
R2 will be some weight once finished, as the left leg has still more to be added and is quite heavy already.
Now have to wait for next months parts so as I can test out the projector. Sad
Peter
Completed - R2D2
semaj
#69 Posted : 29 July 2017 01:19:22
Coming along nicely. I believe the finished weight is around 8.5kg!! You can still plug the screen in to check it works, it just wont project on to a wall. Probably worth checking just to be sure.
Building:
Complete:
Ritchie69
#70 Posted : 29 July 2017 09:04:51
Cheers for the info, just checked plugged in the screen to see if it works ok and all good BigGrin
Peter
Completed - R2D2
Ritchie69
#71 Posted : 30 August 2017 20:52:06
Finally got this months pics onto the PC BigGrin
Been eagerly waiting for issue 29, so I could test the projector.
Issue 29
Well I wasn't disappointed with this issue. Put all parts together very carefully, so as not to get any fingerprints on the lens or disturb the wire into the screen.
Once built it worked as it should BigGrin BigGrin BigGrin
Completed - R2D2
Ritchie69
#72 Posted : 30 August 2017 20:59:58
Issue 30
This part doesn't loo much when there are only 2 parts in this issue, but its probably the most to be done in 1 issue so far.
Added the motor for the leg, then the fun started as we then had to install the motor & foot sensor wires (making sure there is enough slack) then tie them down with the zip strips.
We then put on all the leg casing and screwed it all into place.
Completed - R2D2
Ritchie69
#73 Posted : 30 August 2017 21:07:32
Issue 31
Only the casing of the foot to attach, so not too much.
Completed - R2D2
Ritchie69
#74 Posted : 30 August 2017 21:10:28
Issue 32
Only the foot sensor to attach. More screws to put away for later.
Completed - R2D2
#75 Posted : 30 August 2017 22:14:45
Very nice progress, R2 is certainly growing now....Cool Cool .. Well done...
#76 Posted : 30 August 2017 22:39:22
Nice work, certainly taking shape nowThumpUp
#77 Posted : 02 September 2017 21:06:55
Looking good, nice work. You can start to get a feel for the final size and weight of R2.
Ritchie69
#78 Posted : 02 September 2017 23:07:31
thanks all, really enjoying the build. BigGrin
Completed - R2D2
Ritchie69
#79 Posted : 26 September 2017 19:48:47
That time of the month again BigGrin
Issue 33
Fit the base plate and put the base ring together. Then attach to the dome. The powerbus cables are for the next issue.
Completed - R2D2
Ritchie69
#80 Posted : 26 September 2017 19:56:41
Issue 34
We test the leg motor, then finish off the leg by adding the full cell.
Completed - R2D2
12 Pages «<23456>»
This page was generated in 0.355 seconds.
