106 Pages «<5152535455>»
Sticky Wickett
#1041 Posted : 31 July 2017 18:44:14
tigerace wrote:
i bought the rivets for inside etcBigGrin but will have to get some of those as wellBlink are they from Historex Agents? regards Phil
Hi Phil, not from Historex Agents, bought direct from Archers Transfers, USA. I didn't know HA supplied embossed decals? Confused The Archers' are embossed plastic rivets that you apply the same way as decals and then seal with Microsol, before you apply paint.
Forgive me if you already knew this.Blushing
I will check HA's website.
Phil W.
Sticky Wickett
#1042 Posted : 31 July 2017 18:51:35
Just been on the HA site. They stock Archers Transfers, but only a limited range and unfortunately not the ones I'm after. The price is about the same though.
Thanks for the info!Cool BigGrin
Phil W.
Sticky Wickett
#1043 Posted : 03 August 2017 07:25:42
Morning from 'The Dockyard'.
This weeks update on my U230 build log will look at adding extensions to the casing near to where the conning tower will be located. These extensions were fitted to U-boats which had their conning towers modified from a Turm II to a Turm IV, including U230. U230 had already been a sea going vessel for some time before it received these extensions. Later on, all U-boats were fitted with a Turm IV conning tower and extensions from new.
The Turm IV type conning tower has an extra lower platform to facilitate a 3.3cm gun. To allow the crew to walk around a Turm IV tower, extensions were added to the casing as the previous space was now very narrow.
After studying photos of U995, which was fitted with these from new, I could determine their location on my build.
The attached photo shows my diagram with dimensions.
Sticky Wickett
#1044 Posted : 03 August 2017 07:29:23
After cutting out two pieces of 0.5mm plastic sheet to the overall size I could then mark out and cut a curve to represent their outer edge.
The only thing I could find of suitable diameter was a plate!LOL
The photo shows the curves being marked out.
Sticky Wickett
#1045 Posted : 03 August 2017 07:30:51
Using the same plate I could also mark out a curve on some tread plate.
Sticky Wickett
#1046 Posted : 03 August 2017 07:31:45
Tread plate cut and then glued to the plastic profile.
Sticky Wickett
#1047 Posted : 03 August 2017 07:32:29
Port and starboard pieces with tread plate attached.
Sticky Wickett
#1048 Posted : 03 August 2017 07:34:41
These were then offered up to the boat to determine how I was going to support them and in doing so, realised the etched brass rivet plates would have to be removed.
The attached photo shows the first one being lifted away.
Sticky Wickett
#1049 Posted : 03 August 2017 07:36:56
I then had to make supports so that the extensions would locate horizontally against the angled casing.
This photo shows the angled supports.
Sticky Wickett
#1050 Posted : 03 August 2017 07:38:07
They were tricky to make as I had to keep checking that the extensions would sit level.
Sticky Wickett
#1051 Posted : 03 August 2017 07:39:31
Another view showing the angled supports. I had to also ensure I had left an edge for the outer covering to be fixed too.
Sticky Wickett
#1052 Posted : 03 August 2017 07:40:48
This photo shows a close up of one of the extensions.
Sticky Wickett
#1053 Posted : 03 August 2017 07:44:47
This photo shows the port extension fixed in place, sitting level against the angled casing sides.
Sticky Wickett
#1054 Posted : 03 August 2017 07:46:08
An overhead view showing both port and starboard extensions fitted.
Sticky Wickett
#1055 Posted : 03 August 2017 07:47:19
This photo shows the extensions level with the top of the casing.
Sticky Wickett
#1056 Posted : 03 August 2017 07:49:42
To make the outside contours I used 0.5mm plastic sheet. The attached photo shows the first piece, glued at one end, being checked for fit.
Sticky Wickett
#1057 Posted : 03 August 2017 07:50:52
Two pieces fitted. The same technique was used for the other extension.
Sticky Wickett
#1058 Posted : 03 August 2017 07:52:39
Plenty of time was then spent on filing these plastic pieces to suit, followed by filler and then more filing.
Sticky Wickett
#1059 Posted : 03 August 2017 07:53:43
From another angle.
Sticky Wickett
#1060 Posted : 03 August 2017 07:54:21
Port side.
Guest (27)
This page was generated in 1.518 seconds.
