106 Pages «<5253545556>»
Sticky Wickett
#1061 Posted : 03 August 2017 07:55:32
A plan view showing the completed casing extensions.
Sticky Wickett
#1062 Posted : 03 August 2017 07:58:09
Overall, i was very happy BigGrin with the way these modifications turned out; blended curves that sit well against the angled casing sides.
Sticky Wickett
#1063 Posted : 03 August 2017 08:00:44
That completes this weeks update. Next week I will be looking at applying the embossed plastic rivet heads.Cool
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
#1064 Posted : 03 August 2017 14:06:17
Yet another excellent update PhilBigGrin Drool regards PhilCool
#1065 Posted : 03 August 2017 14:06:37
Excellent work as always Phil and well done on those extension pieces, very well executed. Cool ThumpUp
#1066 Posted : 03 August 2017 16:08:17
Great work Phil Cool superb build.
#1067 Posted : 03 August 2017 18:31:38
BigGrin Nice work and looking goodCool
#1068 Posted : 03 August 2017 18:43:36
That's really looking very good, excellent work.
#1069 Posted : 03 August 2017 20:07:06
Fantastic Phil, keep them coming Cool
Sticky Wickett
#1070 Posted : 07 August 2017 10:33:10
Thanks Phil.Cool Your comments are always welcome!BigGrin
Phil W.
Sticky Wickett
#1071 Posted : 07 August 2017 10:34:12
Thanks Kev!Cool Your comments are much appreciated!BigGrin
Phil W.
Sticky Wickett
#1072 Posted : 07 August 2017 10:35:14
Thanks very much Al!Cool Your comments are much appreciated!BigGrin
Phil W.
Sticky Wickett
#1073 Posted : 07 August 2017 10:35:51
Thank you very much Andy!Cool BigGrin
Phil W.
Sticky Wickett
#1074 Posted : 07 August 2017 10:36:52
Thank you Mark for you comments and support!Cool BigGrin
Phil W.
Sticky Wickett
#1075 Posted : 07 August 2017 10:37:36
Thank you Dave for your encouraging comments!Cool BigGrin
Phil W.
Sticky Wickett
#1076 Posted : 07 August 2017 10:38:39
More updates to follow later this week.
Phil W.
Sticky Wickett
#1077 Posted : 10 August 2017 21:28:26
Over the course of the next few weeks of my U230 u-boat build log I will adding rivets, weld lines and draught marks.
The rivets were bought from Archers Transfers in the U.S. They come as sheets with the embossed plastic rivet heads in lines which you can then cut into strips of any length. They are applied in the same manner as wet transfers, the only difference being they are laid before you apply paint as this then completely seals them. As standard practice I applied Microsol fixative once they were in place to ensure they adhered properly in readiness for undercoat.BigGrin
Archers Transfers stock a wide range of rivets in various different scales and also weld lines and other details. They aren't cheap, well they are if you're building a tiny ship or plane but not for a 1/48 U-boat!BlinkLOL
They do a rivet set for a 1/72 U-boat but not 1/48 scale unfortunately, so it was a case of choosing the best match I could find. My final decision on what rivet spacing best suited my U-boat happened by accident. After trawling through their range of 1/35 and 1/48 scale rivet sheets i couldn't find any suitable until i looked at a HO scale [1/76] bridge rivet set. Viola! The spacings matched my measurements, so I ordered 4 packets! Gulp!Crying 12 days later they arrived. It then dawned on me pretty quickly that 4 packets wasn't going to be enough. Oh no!Blink
In the interim I decided to make a start with what I had. Initially it was very fiddly laying strips with only 4 rivets on, however, i eventually got the hang of it and was soon 'in the groove'.
The following photographs show the port and starboard upper bow having rivets applied. This isn't a 5 minute job, so the sheets I have will take the same amount of time to lay as my resupply order takes to arrive.
The attached photo shows the upper starboard bow being marked out in pencil to act as a guide when laying the rivet strips.
Sticky Wickett
#1078 Posted : 10 August 2017 21:29:22
Laying the small strips with four rivets on each.
Sticky Wickett
#1079 Posted : 10 August 2017 21:30:44
Upper, starboard bow complete.
Sticky Wickett
#1080 Posted : 10 August 2017 21:32:32
This photo shows the transfers freshly applied prior to the Microsol.
Guest (10)
This page was generated in 0.848 seconds.
