7 Pages <12345>»
May's Adopted BTTF Delorean Build Options
MFG
#41 Posted : 15 July 2017 18:37:37
Hi,
So as I said at the start of todays posts I've ended up with 5 extra issues, they are of no use to me so if anyone would like them for replacement parts or whatever and you live here in the UK then you are welcome to them.
They are all still unopened in the film wrapper and are being offered free of charge - I don't want anything for them after all they didn't cost me anything so really I'm just passing them on
Just to re-cap then the issues I have are
1 x 24
1 x 25
1 x 26
2 x 27
These issues have now found a new home BigGrin and are no longer available - sorry
May.
#42 Posted : 15 July 2017 21:00:23
That's a very generous offer May, I'm sure somebody will take you up on it.
MFG
#43 Posted : 15 July 2017 21:11:54
Hi Al,
Thank you, well hopefully somebody will have some use for them on here, if not then I'll "pop" them on ebay as a charity auction
May.
#44 Posted : 16 July 2017 11:09:46
Pm sentBigGrin regards PhilCool
MFG
#45 Posted : 16 July 2017 12:28:10
Hi Phil,
I've replied to your pm BigGrin
May.
#46 Posted : 16 July 2017 12:34:17
Yep thankyou May BigGrin philCool
MFG
#47 Posted : 20 July 2017 11:27:50
Hi,
Picked up issue 29 from the newsagents this morning apparently there's some kind of shortage with issue 28 so she couldn't get a copy for me and it's still showing on the online store as out of stock but I did manage to find one on ebay although a little dearer at £11 but at least I have one on the way, and I can now pick this one up weekly as well along with the Jag BigGrin
May.
#48 Posted : 20 July 2017 15:06:59
So you got the first part of the floor then May?Confused regards PhilCool
MFG
#49 Posted : 20 July 2017 17:52:00
Hi Phil,
Yes I have the floor plate, which you can see being installed in the vid link below if you are interested, but I have to wait until #28 to arrive before I can do mine Sad
https://www.youtube.com/watch?v=VU4d6h0hNgQ
May.
MFG
#50 Posted : 20 July 2017 18:01:36
Hi,
Sorry forgot to select the attach file option - again Blushing
May.
MFG attached the following image(s):
MFG
#51 Posted : 25 July 2017 12:41:17
Hi,
Issue 28 arrived via ebay yesterday so this morning I worked through this and last weeks issues BigGrin
Issue 28
Radiator
All of the parts went together with little fuss, although I was a AP screw short as they had only supplied 5 but I have plenty of spares so it didn't matter.
May.
MFG
#52 Posted : 25 July 2017 12:49:14
Hi,
Issue 29
Chassis Plate
I tried various ways to prop the chassis up whilst I attached the plate, in the end I settled for using two car sponges!! the plate it's self went on fine - this build is starting to get heavy BigGrin
With any luck I should be able to pick up this weeks issue 30 on Thursday from my new favourite newsagents BigGrin
Thanks for dropping by
May.
#53 Posted : 25 July 2017 14:16:59
Great update MayBigGrin really quite a big modelDrool regards PhilCool
MFG
#54 Posted : 25 July 2017 16:46:33
Hi,
Thanks Phil, it's 52.7 cm in length according to the poster that came with issue 1 and it's really heavy to,
May.
MFG
#55 Posted : 27 July 2017 20:11:04
Hi,
Picked up this weeks issue today BigGrin
Issue 30
Water Pipes
I found that working though the steps in a different order to what is shown in the magazine made "life" a little easier as I didn't have to constantly turn the chassis over all the time, so I did steps 1, 7, 2, 3, 8, 9, 6, 5, 12, 11, 4 and 10. Doing 6 before 5 and 12 before 11 made installing parts 30 c & g a lot easier
You see, I'm learning BigGrin this weeks lesson - It's important to read though the instructions before making a start as the instructions don't always follow the most convenient route!!
May.
stevegbr
#56 Posted : 27 July 2017 20:13:19
looking good may, it is a beast.LOL LOL
MFG
#57 Posted : 27 July 2017 20:17:28
Hi,
Thank you Steve,
Your not wrong, I'm having to store it in a box my new microwave came in as I don't have anything thing else big enough!!!
May.
MFG
#58 Posted : 03 August 2017 13:01:14
Hi,
So this morning I braved the weather to pick up this weeks issue BigGrin
Issue 31
Rear Chassis Plates
My trusty car sponges will now no longer support the weight of the chassis Sad but I did spot a set of four tall glasses in a local charity shop window which do the job just fine BigGrin
As for the build, some of the screws needed a bit of encouragement to line up with the receiving holes in the chassis but once I had a grip they went in just fine.
May.
#59 Posted : 03 August 2017 14:05:02
looking good there MayBigGrin regards PhilCool
stevegbr
#60 Posted : 03 August 2017 14:05:37
well done may, you have caught up,BigGrin just in time to start again.LOL
Guest (11)
7 Pages <12345>»
This page was generated in 0.279 seconds.
