Will you be sculpting any fish to put in the fish boxes Jack? I think that would be a very nice touch?
Kev
Love everything about his build Jack, looks fab.... Regards Alan
Joined: 28/05/2014 Posts: 938 Points: 2,823 Location: Milan (Italy)
Considerations about the sails of the Gajeta . .The Gaeta (Gajeta) Falcata (Falkusa) seems to be a very versatile boat. We learned how this boat can be used with two hull configurations, one with high sides, optimized for sailing and one with lower sides, most suitable for fishing with nets. But its versatility also manifests itself in its sails. Let's think about them. The following image shows three Gaeta configurations, from left to right: a) sails with "high" main sail; the main sail is very high, probably suitable with light winds; b) sails with "low" main sail; the sail is not triangular and mounts a beam even below; c) no masts/beams and sails; configured with low sides suitable for fishing; the rudder has been removed. 01 Falkusa-1_zpswokpwsjz.JPG  The following image shows a Gaeta in configuration type (a); for my taste this is the most beautiful and majestic. And here we can also look at another variant: the double jib, interesting . . 02 Velatura Alta 01.jpg  Here below the boat is in the configuration type (b): lower sail, jib fastened half way on the bow beam, although we have seen that it can be fastened on the top of the bow beam. The main sail may seem triangular but seems to be rolled on the lower beam and for this reason doesn't look like in the image 01 . . 03 Velatura Bassa con Tangone.jpg  Here are other images with an apparently "low" sail but with a real triangular shape. Images 04, 05, 06 and 07. Let's say this is a new type . . we'll define Type (d); obviously this is another sails configuration !! 04 Velatura Bassa 01.jpg  05 Velatura Bassa 02.jpg  06 Velatura Bassa 03.jpg  07 Velatura Bassa 04.jpg  For now I have not found more configs, but it's not said that they do not exist. For reasons related to the size (height) of the plexiglass cover for the showcase, although my preference goes to the sails type (a), I decided to adopt the configuration type (d). The kit features pre-sewn, well-made sails. Unfortunately they are for the configuration type (a) and to transform them into sails type (d) there is some work to do: the main sail needs to be ex novo rebuilt. But here some problems arise: I do not have the same fabric and so I should also redo the jib; but I'm also a dud with the sewing machine, so the result could be bad if not worse. So ? Simple, I will install the original jib and the main sail tied to its beam as in the images below . . With this solution I just need to cut the big sail to the right extent and the game is done; once rolled on the beam its wrong shape will no longer be visible . . Hyper-pragmatic solution . . See you next time, Jack. 08 Alla fonda 01  09 Alla fonda 02  10 Alla fonda 03
Tuesday 15 August 2017I almost finished the buckets !! Now it just miss the painting of the brass handles with "gun metal" and they're over. Today my wife did a very good job with sails that are almost finished . . I need now only to hold the wire knots with a drop of glue.
Two photos of the buckets where you can see also a small detail of a sail.01 20170815_183303.jpg  02 20170815_183341.jpg Goodbye, Jack.
Thursday 17 August 2017Having finally finished all the various detail components, yesterday and today I was able to begin working on the masts and its rigging. The pictures below show the work done so far . . far from being near completion. However, the goal is behind the corner, maximum another week, then it will be time to setup the beach of Comiso on the displaycase . . See you soon, Jack.01 20170817_121338.jpg  02 20170817_121400.jpg  03 20170817_121416.jpg  04 20170817_121526.jpg  05 20170817_122911.jpg  06 20170817_122929.jpg
Friday, August 18th, 2017The commissioning is in progress . . 01 20170818_121149.jpg  02 20170818_121210.jpg  03 20170818_121200.jpg  04 20170818_121423.jpg The rudder installed e working fine . .05 20170818_122632.jpg  See you soon, jack.
really is a top top job Jack  very impresive work  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Tuesday 22 August 2017At this point the model is practically finished . .Now I have to prepare and apply the rope curls to add realism to the edges of the running rigging and then there is nothing left to do.
In the next days I'll focus on the setup of the displaycase basement, according to the idea I described some time ago (rocky beach, various accessories left on the beach, etc.)
Soon, Jack.01 20170822_121019.jpg  02 20170822_121033.jpg  03 20170822_121049.jpg  04 20170822_121101.jpg  05 20170822_121110.jpg
One word: Superb! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Beautifull Jack  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thanks Phil W. and Phil for your very positive comments, thanks again, Jack.Tuesday 22 August 2017Other new images . .01 20170822_121116.jpg  02 20170822_121124.jpg  03 20170822_121130.jpg  04 20170822_121140.jpg  05 20170822_121337.jpg
Absolutely amazing build Jack. I've been following this throughout and I'm overwhelmed with your eye for detail and your skill in putting it all together. Happy building David
daffy09 wrote:Absolutely amazing build Jack. I've been following this throughout and I'm overwhelmed with your eye for detail and your skill in putting it all together. Happy building David Thank you very much, David, for your comment; thanks again, Jack.Wednesday, August 23, 2017I've finished with the last rigging details, like the rope curls at the ending tips of the running rigging.
With this last activity, the model by itself is truly over . .
Now only the display case is missing in order to close the shipyard. 01 20170823_115552.jpg  02 20170823_115600.jpg  03 20170823_115616.jpg  04 20170823_115621.jpg  05 20170823_115651.jpg  06 20170823_115847.jpg  07 20170823_115854.jpg
Stunning work and a pleasure to see.... Regards Alan
Excellent result Jack. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:Excellent result Jack. Regards delboy271155 (Derek) Gandale wrote:Stunning work and a pleasure to see.... Regards Alan Meny thanks for your positive comments, friends . .Saturday, August 26, 2017I put inside oars and a couple of accessories, just to understand that much of the material I prepared will be better if positioned on the (future) beach . .The next images will show the model inside its display case . . probably by the end of next week, bye, Jack. 01 20170823_120506.jpg  02 20170823_120513.jpg  03 20170823_120529.jpg  04 20170823_120536.jpg  05 20170823_120541.jpg
Monday 28 August 2017I'm working on the display case base . . In particular I'm preparing the so-called "beach". To hold the small pebbles of the Elba Island beach called "200 steps" I used vinyl glue, laid abundantly on the wood basement.
The work is not yet finished because I think it is better to make another layer of this sandblast and then apply the larger pebbles individually. . I now have two new sizes . .
Interesting experience. We will see how the situation evolves. See you soon, Jack. 01 20170828_171348.jpg  02 20170828_171355.jpg  03 20170828_171503.jpg  04 20170828_172334.jpg
Tuesday 29 August 2017The display case setup continues . . Still a few days again . .01 20170829_104314.jpg  02 20170829_104326.jpg  03 20170829_104349.jpg  04 20170829_104358.jpg  05 20170829_104530.jpg  06 20170829_104541.jpg  07 20170829_104548.jpg  08 20170829_104652.jpg
Wednesday, August 30, 2017 - FinishedThese four pictures show the finished project, under its plexiglass cover . .
Due to reflexions and low light the photos are rather poor, but they still make the idea of how the whole complex appears.
Now the adventure is really over.
A further batch of more detailed images, as my customary, will follow soon.
A warm greeting, Jack.Aubrey.01 20170830_103511.jpg  02 20170830_103500.jpg  03 20170830_103450.jpg  04 20170830_103439.jpg
Stunning result Jack, truly a joy to follow.... Regards Alan
