upper deck dummy barrel supports Options
thomasmoult
#1 Posted : 11 April 2011 13:16:08
Just a quick question; the dummy support beams that are fitted on the upper gun deck - will the ends be visible around the central area where the 10 cannons are rigged (i.e, when you look down into the deck, will the ends be seen?)
I'm guessing they wont too much after the fixtures are added etc?
Cheers,
Tom
#2 Posted : 11 April 2011 14:43:08
Barely
This page was generated in 0.022 seconds.
