106 Pages «<5354555657>»
Sticky Wickett
#1081 Posted : 10 August 2017 21:34:38
Looking aft.
Sticky Wickett
#1082 Posted : 10 August 2017 21:38:10
Close up.
Sticky Wickett
#1083 Posted : 10 August 2017 21:39:45
This photo shows the next section marked out in pencil, again, to act as a guide for the transfers.
Sticky Wickett
#1084 Posted : 10 August 2017 21:40:55
Rivets laid.
Sticky Wickett
#1085 Posted : 10 August 2017 21:41:43
Looking forward.
Sticky Wickett
#1086 Posted : 10 August 2017 21:42:45
Anchor well.
Sticky Wickett
#1087 Posted : 10 August 2017 21:44:01
Upper, starboard hull looking aft.
Sticky Wickett
#1088 Posted : 10 August 2017 21:47:09
I then proceeded to mark out the remainder of the vertical rivet guide lines on the forward starboard bow. There are horizontal patterns around the torpedo tube bow caps, but I will add these as i go.
Sticky Wickett
#1089 Posted : 10 August 2017 21:47:57
Another photo showing the pencil guide lines drawn out.
Sticky Wickett
#1090 Posted : 10 August 2017 21:48:58
A side on view.
Sticky Wickett
#1091 Posted : 10 August 2017 21:55:06
I then proceeded to mark out and lay the rivets to their corresponding port side sections.
Sticky Wickett
#1092 Posted : 10 August 2017 21:55:56
Moving forward.
Sticky Wickett
#1093 Posted : 10 August 2017 22:01:55
As with the upper starboard side, I then marked out the remainder of the vertical guide lines. The reason I chose to do it this way rather than lay all of the rivets on one side was to better gauge how many rivets I used and also not having to face the daunting task of laying them all again on the opposite side. I figured that working in small sections on both sides was a better option for me.
Sticky Wickett
#1094 Posted : 10 August 2017 22:02:56
Port side bow.
Sticky Wickett
#1095 Posted : 10 August 2017 22:04:17
U-boat inverted showing the guide lines drawn all the way down to the keel.
Sticky Wickett
#1096 Posted : 10 August 2017 22:05:25
Lower port side hull guide lines.
Sticky Wickett
#1097 Posted : 10 August 2017 22:07:16
This photo shows how the guide lines from both port and starboard sides align on the forward keel. Couldn't have them mismatched could I?LOL
Sticky Wickett
#1098 Posted : 10 August 2017 22:09:50
Well that concludes this weeks update. Next week and probably for a few weeks after thatLOL, i will be continuing with the rivets, weld lines and draught marks.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
#1099 Posted : 10 August 2017 22:54:51
Phil
Fantastic build. That is a lot of dedication you are adding with all that rivit detail. Will all look wonderful under its paint finish
Sticky Wickett
#1100 Posted : 10 August 2017 23:23:42
birdaj2 wrote:
Phil
Thanks for looking in and your encouraging comments Tony!Cool
If I didn't apply the rivets it would be the one thing that would bug me every time I looked at it. BigGrin
Phil W.
Guest (11)
This page was generated in 4.194 seconds.
