106 Pages «<5455565758>»
DaDokta
#1101 Posted : 11 August 2017 06:58:44
Absolutely stunning!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#1102 Posted : 11 August 2017 09:09:28
Gets better and better with every update... love the detail being applied.....Drool Drool Drool
Sticky Wickett
#1103 Posted : 11 August 2017 09:32:32
Thanks for looking in Walter and your kind comments!Cool BigGrin
Phil W.
Sticky Wickett
#1104 Posted : 11 August 2017 09:33:37
Thank you very much for your kind words and encouraging comments Alan!Cool BigGrin
Phil W.
#1105 Posted : 11 August 2017 10:29:32
Fantastic work, the detail is exceptional.
Sticky Wickett
#1106 Posted : 11 August 2017 10:52:37
Thank you very much for your kind words and encouragement Graeme!Cool BigGrin
Phil W.
#1107 Posted : 11 August 2017 12:06:23
Those rivets really make it look awesomeBigGrin it look`s outstanding with all this detailDrool brilliantDrool BigGrin regards PhilCool
Sticky Wickett
#1108 Posted : 11 August 2017 13:24:38
Thanks for looking in Phil and your kind comments.Cool Much appreciated!BigGrin
Phil W.
#1109 Posted : 11 August 2017 14:52:01
I have to agree that the rivets make it look amazing. I looked at the pictures first before reading the text and thought you were placing them all individually LOL LOL Cool
Sticky Wickett
#1110 Posted : 11 August 2017 15:02:02
LOL Dave! If I did that this build thread would last about 10 years!LOL Thanks for looking in and your encouraging comments. Much appreciated.
Phil W.BigGrin
#1111 Posted : 11 August 2017 20:45:11
Your definitely going that extra bit with adding the rivets but they certainly look great Cool
Sticky Wickett
#1112 Posted : 14 August 2017 09:10:28
Thanks for looking in Al!Cool Much appreciated!BigGrin
Phil W.
Sticky Wickett
#1113 Posted : 17 August 2017 22:54:38
This week's update continues with riveting the bow section using embossed plastic transfers.
Quite a slow job and not without mistakes as decals would tear, curl up, twist or get accidentally rubbed off as I handled the boat!Blushing.
The attached photo shows the continuation of the rivet lines on the port side.
Sticky Wickett
#1114 Posted : 17 August 2017 22:55:15
Working forward on the port side.
Sticky Wickett
#1115 Posted : 17 August 2017 22:57:34
This particular section on the port side completed, looking aft.
Sticky Wickett
#1116 Posted : 17 August 2017 23:05:26
In this photo to the left of the last line of rivets you can see a vertical pencil line crossed at intervals. This is the marking out for the port bow draught marks.
Type VIIC U-boats had six draught marks; three on the port side [bow, mid-ships and stern] with the same layout on the starboard side.
I wanted to get the draught marks fixed before I continued with the embossed rivets to make them easier to apply.
Sticky Wickett
#1117 Posted : 17 August 2017 23:08:24
I used photo-etched brass numbers supplied by Cornwall Model Boats. The smallest set of numbers were the ones most suitable as they are 1.0mm high equating to 2" [50mm] on the real thing.
The attached photo shows the etched brass fret.
Sticky Wickett
#1118 Posted : 17 August 2017 23:12:42
This photo shows a piece of electrical tape being used as a guide as to where the numbers would be fixed. Not only is the tape acting as a datum edge so the numbers are in line but also as a rule with the 2.0mm spacings marked onto the tape.
Sticky Wickett
#1119 Posted : 17 August 2017 23:14:07
This photo shows the 1.0mm high numbers fixed to the port bow, aligned with the markings on the electrical tape.
Sticky Wickett
#1120 Posted : 17 August 2017 23:23:23
These draught marks are at the actual scale height as per the real U-boats.
As you can see the top number is zero, descending in value down to one [0, 9, 8 etc]. The zero on the real u-boats represents 50 decimetres [10 decimetres per meter], or 5 meters from the bottom of the keel. Dividing this number by 48 [1/48 scale] is approximately 104mm. This measurement was marked onto port bow and the tape with the markings was stuck so that the top edge of the tape aligned with that mark.
The number nine represents 49 decimetres, number eight is 48 decimeters and so on. This system is used on the bow and midships draught marks only, the stern is slightly different and I will cover this in a later update.
Guest (20)
This page was generated in 2.030 seconds.
