7 Pages «<23456>»
Ian's E-Type build diary Options
#61 Posted : 12 August 2017 18:56:37
Looking good Ian, lovely progress....Cool Cool
#62 Posted : 12 August 2017 19:45:34
BigGrin Progressing rather nicelyCool
#63 Posted : 12 August 2017 20:14:09
Looking good Ian BigGrin
Ian23
#64 Posted : 13 August 2017 13:52:51
Thanks guys, can't wait till we can start pulling all the bits together
Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Built: Deagostini Millennium Falcon
#65 Posted : 13 August 2017 20:23:53
Looking good Ian.BigGrin
Keep up the good work.
Cool Cool Cool Cool
Ian23
#66 Posted : 10 September 2017 15:57:23
Back to the build and the subframe takes shape
Build the Jaguar E-Type, Part 22
Parts with issue 22
Left upper wishbone
Left lower wishbone
Left suspension upright
This is like stage 20. Take the inner side member from stage 21 and align the wishbones from this stage with the 2 indicated pivot holes. (Picture 2)
Take the suspension upright and fit it over the 2 pivot holes, aligning the fixing holes. Secure the suspension upright in place with 2 screws. (Picture 3)
Ian23 attached the following image(s):
Ian23
#67 Posted : 10 September 2017 16:02:38
Build the Jaguar E-Type, Stage 23
Parts with Issue 23
Front Crossmember
Take the Crossmember from this issue and the 2 sidemember assemblies, assembled previously.
Take the left hand side member and slide it into place taking note of the orientation. Secure with 2 screws as indicated. (Picture 2)
repeat for the right hand side member, making note of the alignment shown. (Picture 3)
Ian23
#68 Posted : 10 September 2017 16:12:20
Build the Jaguar E-Type, Part 24
Parts with Issue 24
Right hand upper brace
Right hand diagonal brace
Take the subframe assembly and the upper brace. Fit the cranked square on the brace against the front crossmember. Holding the brace in place and turn the assembly over. Secure the brace to the side member through the middle of the side member. (Picture 2)
Take the diagonal brace into the hole just above the wishbone pivots and align the other end with the corresponding hole in the upper brace. Secure with a single screw. (Picture 3)
Ian23
#69 Posted : 10 September 2017 16:18:00
Build the Jaguar E-Type, Stage 25
Parts with issue 25
Left hand upper brace
Left hand diagonal brace
This is the same as the previous stage.
Take the upper brace and align it as before. Secure with a single screw as before (Picture 2)
Take the diagonal brace and secure in with a single screw as before (picture 3)
Ian23
#70 Posted : 01 October 2017 15:21:53
New delivery brings more of the frame
Build the Jaguar E-Type, Stage 26
Parts with Issue 26
Left hand lower brace
Right hand lower brace
Steering rack mounting bracket
Oil filter
Take the subframe assembly and the steering rack mounting bracket and align the 2 parts securing with a single screw (picture 2)
Take the left hand lower brace and align as shown in the instructions and secure with a single screw (picture 3)
the right hand lower brace and the oil filter will be fitted at a later stage
stevegbr
#71 Posted : 01 October 2017 15:25:40
looking really good ian, starting to take shape. BigGrin
Ian23
#72 Posted : 01 October 2017 15:33:44
Build the Jaguar E-Type, Stage 27
Parts with issue 27
Right suspension upright
Brake disc
Caliper
Suspension brushes
Shock absorber shroud
Coil spring
Damper body
Pivot pin
Take the brake disc and the caliper and slide over the edge of the disc. Align he disc assembly over the central spindle and fit the locating post into the hole in the caliper. Secure with a single screw. (picture 2)
take the assembly and the subframe and align with the ends on the wishbones. Fit the brushes over the wishbones and secure with 2 screws from below and above. (picture 3)
take the shock absorber shroud and fit the eye into the bracket on the front cross member. Secure with the pivot pin ensuring the splined end goes in last. put the coil spring into the shroud and fit the damper over the spring. secure to the lower wishbone with a single screw. (Picture 4)
Ian23
#73 Posted : 01 October 2017 15:36:41
Build the Jaguar E-type, stage 28
Parts with issue 28
Brake disc
Caliper
Suspension brushes
Coil spring
Damper body
Pivot pin
This stage is identical to the previous stage, just on the left side og the frame
Ian23
#74 Posted : 01 October 2017 15:40:34
Build the Jaguar E-Type, Stage 29
Parts with Issue 29
Sump
Torsion bar assembly
Take the 2 parts provided and align them fitting the 3 prongs into the slot in the sump. (picture 2)
Ian23
#75 Posted : 01 October 2017 15:42:19
and this brings another month to an end. it's really starting to come together now. won't be long until it starts looking like a carBigGrin BigGrin BigGrin
#76 Posted : 01 October 2017 18:38:51
Looking good Ian and coming together nicely Cool
#77 Posted : 01 October 2017 22:33:14
You're doing a great job Ian, looks great....Cool Cool
#78 Posted : 01 October 2017 23:22:07
Looking good Ian Cool Its also starting to gain some weight with all that metalwork.
Ian23
#79 Posted : 02 October 2017 09:58:11
Thanks guys. This is going to be a heafty beast when it’s done!
Ian23
#80 Posted : 05 November 2017 17:00:45
New month means new parts and this month is a busy but fiddly one. The result is great though
Build the Jaguar E-Type, Stage 30
Parts with Issue 30
Radiator header tank
Header tank support
Fan motor assembly
Cooling fan
Hose
Filler cap
Fit the fan onto the motor shaft and secure with a single screw (picture 2)
Fit the header tank too its support and secure with a single screw (picture 3)
Line the motor assembly and the support up and secure together with 2 screws (picture 4)
Line the filler cap up with the hole in the header tank and push firmly into place. (picture 5)
The hose will be attached at a later stage
7 Pages «<23456>»
This page was generated in 0.312 seconds.
