Thank you for all the comments guys. Mark Regards Markwarren (Mark) Admin
Really looks great Mark  lovely weathering  regards phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Joined: 12/01/2017 Posts: 572 Points: 1,731 Location: Cambridgeshire
Really excellent. Although I will not be lighting mine, I hope mine comes out half as good as that. It's been a real treat to keep looking in. Gary Current Builds Eaglemoss: Ecto-1, BTTF Delorean [Installing Mods] Hachette: T800 Endoskeleton Agora Models Shelby Cobra 427 [Plate 031] BanDai 1:5000 Imperial Star Destroyer AMT 1991 U.S.S. Enterprise Bridge [Installing Mods & Lights]
Finished Builds Deagostini: R2-D2 [Never getting batteries]
 Rank: Semi-Pro Level 2 Groups: Registered
Joined: 08/05/2016 Posts: 79 Points: 251 Location: Perth, W.Australia
G'day Mark , Really beautiful finish on C3-PO . Was wondering what type of varnish you used ( semi gloss / satin , gloss ) , and by whom ? . Asking cause I've tried varnishing ' chrome - plated ' type plastic before , and never achieved results like you've done . Cheers Ged
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Looks awesome ,can't wait to see the finished diorama. Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Many thanks for your comments and support everyone. Just hope I can do a similar job with R2. Mark Regards Markwarren (Mark) Admin
gedmac66 wrote:G'day Mark , Really beautiful finish on C3-PO . Was wondering what type of varnish you used ( semi gloss / satin , gloss ) , and by whom ? . Asking cause I've tried varnishing ' chrome - plated ' type plastic before , and never achieved results like you've done . Cheers Ged Hi Ged Thank you for you kind words, the varnish I used was Rustoleum crystal clear gloss. I rubbed certain parts lightly with micro mesh 12000, not much though. I then used brown tracker wash, once dried then gave several light coats of varnish. I then used mig oils sand colour and dry brushed over the body, using a cotton bud to rub off in places to highlight areas. To be honest it was all very much trial and error. Regards Mark Regards Markwarren (Mark) Admin
Great work in such a scale, very impressive. Also the other impressive milestone of 1000 posts, so CONGRATS on your "Purple" medal. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Many thanks Derek Regards Mark Regards Markwarren (Mark) Admin
the finish on C3PO is superb Mark.
Joined: 04/05/2011 Posts: 173 Points: 528 Location: Sussex
They look superb.
Looks fantastic Mark. Love the lights you have put in. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thank you for your comments and looking in. Regards Mark Regards Markwarren (Mark) Admin
I have been weathering R2 over the last week, dismantled the legs to access the difficult areas. I started with both legs before moving into the body. Once weathered, I will allow to dry before sealing it with a satin varnish.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Next, was to move onto the electronics. Here you can see, I will be using this black box which will hold all the wiring which will be imbedded into the base of the display stand, along with the circuit board with remote.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Then onto the base itself. Before I start the diorama, I will hollow out the under part of the base to hold the circuitry. I have also drilled two holes on the top which will allow the wiring from both C-3PO and R2-D2 feet to go through to the base. Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Then I drilled out the hole at the back of the display for the 12v mains adapter to connect.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
I then placed the female connector through the display base as shown. I also temporarily placed the circuit board in place for test purposes.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
And here it is with the 12v adapter fitted.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Guest (8)
