EXPO AF186 AIR COMPRESSOR Options
daffy09
#1 Posted : 15 August 2017 13:05:26
https://www.alwayshobbies.com/model-boats/model-boat-display-kits#q=pageitems.160Hi friends,
Needed a new air compressor for my L'HERMIONE build, so I had a look at what was available and found this one at my local (if you can call a 1 hour drive local) hobby shop.
Air pressure gauge
Air filter
Adjustable locking pressure
Continuous working
Thermally protected
Low noise 47db
Auto start/auto stop function
Built in fan
Power 1/6 HP
Auto start @ 3 bar(43 psi)
Auto stop @ 4 bar (57 psi)
Air flow 20 - 28 L/min
Net weight 5.0kg
Air tank 3.0 L
All this for under £100
Did have to purchase an air line and airbrush separately though
Happy building
David
daffy09 attached the following image(s):
greyhawk
#2 Posted : 15 August 2017 14:15:48
I love the type 186 compressors. They're all the same model from the same Chinese factory really and every importer slaps on their own label, but they're so so quite and robust.
#3 Posted : 15 August 2017 21:17:10
BigGrin Nice starter set and should do you wellCool
This page was generated in 0.170 seconds.
