replanking the gallery supports Options
ronald305
#1 Posted : 16 August 2017 21:34:51
Hi Alan
in your victory build video when you was finished planking the bottom of the gallery support and getting ready to cut the end pieces were they cut straight
from the hull to end of the supports or did the cut have a curve to it
Ronald
#2 Posted : 16 August 2017 22:43:37
Hi Ronald, the video shows you laying a plank along the side of the hull onto the gallery supports, drawing a line on the gallery planks and cutting along that line. There isn't a curve, just a straight cut....Cool Cool
ronald305
#3 Posted : 17 August 2017 01:51:28
ok thanks Alan wanted to make sure
Ronald
ronald305
#4 Posted : 18 August 2017 15:24:22
Hi Alan
I forgot to ask is ok to end up with a gap between the last plank and the hull
or do I fill it with a piece of wood strip thank you
Ronald
#5 Posted : 18 August 2017 20:03:21
ronald305 wrote:
Hi Alan
Ronald
Hi Ronald, I think a pic of this would be helpful. I need to be sure before giving you a definitive answer.....
ronald305
#6 Posted : 19 August 2017 01:06:54
according to your video which I watched again pack 2 stage 11-20 you did mention to get refine a piece of plank to fit in the spot, anyway I haven't started replacing the planks yet
Ronald
#7 Posted : 19 August 2017 09:43:23
Hi Ronald, I think you are referring to planking the sloping section under the gallery. As you plank this area towards the transom you will end up with a gap between the last plank laid and the transom itself. This gap will need to be filled with another plank that you will need to shape in order to fit, as shown on the video itself...Cool Cool
ronald305
#8 Posted : 20 August 2017 00:25:22
yes that is the area thanks Alan
Ronald
This page was generated in 0.113 seconds.
