Need paint color please . Options
carlton
#1 Posted : 23 August 2017 23:38:11
Rank: Beginner Level 3
Any one know what color paint is on the die cast leg part ? I cleaned up some cast lines didn't know it was painted . Thanks Confused
#2 Posted : 24 August 2017 07:19:54
Hi Calton
If you take a look at the custom build log here, you will see I have painted all the parts and show which paints to use.
For the silver parts, I too have taken off the seam line, primed and the painted with Rustoleum metallic silver.
Hope that helps, here is the link.
http://forum.model-space...spx?g=posts&t=21896
carlton
#3 Posted : 24 August 2017 14:57:19
Ok thanks, I will check the custom build for some ideas .
OTSW77
#4 Posted : 17 February 2018 19:52:07
Rank: Amateur Level 1
Markwarren wrote:
Hi Calton
Hi Mark, first I have to say thank you for logging all your paint work. It's gorgeous. I have a question for you. What are the stock numbers for the blue and purple Tamiya paint you are using? I can't read them in the picture. Are you using Tamiya primer too?
I get my first set of issues this coming week and would like to order the correct paints. Thank you.
Matt
#5 Posted : 18 February 2018 11:20:46
Hi Matt
Here are the pictures of the tops of the Tamiya paints. I am using Rust-oleum surface primer.
Just a tip, allow the silver paint to dry for at least 48 hours before applying the blue and purple paint. Then again allow these to dry before putting on the gloss varnish.
I look forward to seeing your progress soon.
OTSW77
#6 Posted : 18 February 2018 20:56:07
Markwarren wrote:
Hi Matt
Thanks Mark. How many cans do you think we need of the blue and purple?
I have been researching paints and the Rust oleum satin white and silver that you use are not available in the US. What is available is kylon maxx satin white and Metallic Silver. I have used the their flat black for light blocking the falcon. It worked well.
So to get this right I need to do these steps?
Blue parts.
1a adhesion promoter
1b Primer
2 metallic silver
3 mask
4 tamyia Purlple
5 tamyia metallic Blue
6 clear gloss
White parts
1b Primer
2 metallic silver
3 mask
4 satin white
Thanks for your time
#7 Posted : 18 February 2018 22:13:47
I’m supprised you can’t get hold of the Rust-oleum paint as they are usually available from Amazon and are a US paint. As for how many cans of blue and purple you need, I’m not sure, I have bought quite a few, but will probably need more to complete.
When painting the blue parts, I only use the adhesion promoter on the metal pieces.
Primer
Silver
Purple
Blue
Purple again, light coat
Then varnish
Just make sure you use the same combination all the time so they look the same.
As for the silver and white, if you can’t get any Rustoleum paints, then a good satin white will do and a metallic silver should be fine. The one you have seen should work fine.
Hope that helps
My method was all trial and error but seems to work and give a good result, although quite long winded. I would recommend you try it out first on a trial piece, so you know how it all comes together.
Regards Mark
OTSW77
#8 Posted : 19 February 2018 00:03:54
The rust oleum that you use is listed at $56 a can on Amazon. I can get other Rust oleum.
#9 Posted : 19 February 2018 08:27:44
Wow, that’s expensive, I think I paid £9, about $7 maybe $8 in your money. I would use another if I was you.
semaj
#10 Posted : 22 February 2018 02:48:54
On a side note, does anyone know what colour blue de agostini have used on the metal parts? Im asking for a friend, as the blue stripe on his dome dosent quite go all the way around and its a bit of a mess right at the front. He dosent want to have to paint everything a different colour, so just wondering what colour to use to blend it back in as best as possible
Building:
Complete:
#11 Posted : 22 February 2018 08:13:59
Why not just obtain a replacement dome? The blue is a specific blend which is not openly available as a match though he might find something close.
semaj
#12 Posted : 22 February 2018 17:15:21
Fair enough. Thought it would be a bit OTT asking for a replacement just for the sake of a little smudge of paint
Building:
Complete:
This page was generated in 0.980 seconds.
