2 Pages 12>
cals build Options
cal
#1 Posted : 14 April 2011 21:37:36
my build so far issue 25 almost complete will add more as i progress didnt see teh point of doing one up untill now all tips & commente good or bad greatly recived Laugh BigGrin Laugh BigGrin
jimbobuk05
#2 Posted : 18 April 2011 15:53:16
Hi there,
Your build is looking good. Just a couple of issues ahead of me.
You must be pleased with it.
Jim
cal
#3 Posted : 18 April 2011 17:58:55
thanks jim im really pleased with it so far only prob i can see i might have is by the cut out it seems to dip in quite a bit only noticed sice i put on planks 11 & 12
jimbobuk05
#4 Posted : 19 April 2011 11:12:33
I know what you mean. I am probably gonna have the same problem.
Not going to worry about it too much though.
cal
#5 Posted : 22 April 2011 12:14:40
build up to issue 29 im leaving the cannons & anchors untill there needed to be installed
#6 Posted : 23 April 2011 09:50:19
Looking good cal...keep the pictures coming...ThumpUp
cal
#7 Posted : 23 April 2011 21:26:20
cheers jonny will do
cal
#8 Posted : 30 April 2011 14:18:16
upto issue 33 just starting to line the gun ports now
#9 Posted : 30 April 2011 15:33:53
Have fun cal, just finished lining mine...I found it easier to line the left hand side of the ports, then right, (port and starboard) followed by bottoms then tops...took me almost a week, but looks a lot better...Now the lower hull planking...this is where the cursing will start!!...
Blink
Enjoy your build mate...
BigGrin
cal
#10 Posted : 30 April 2011 18:48:04
its taken me all afternoon to do the left side of one side of the ports been told to wait until kids in bed b4 staring the lower planking so they dont here me curse lol
cal
#11 Posted : 28 June 2011 20:33:14
garboard plank fitted many thanks to jonny7 & son of bulwark for their pics & advice
#12 Posted : 28 June 2011 21:18:10
Its coming along leaps and bounds mate...looking good...ThumpUp
cal
#13 Posted : 09 July 2011 14:12:53
progress up to issue 37
#14 Posted : 09 July 2011 14:34:26
Hi Cal, your build is looking very good, you should be very pleased wiyh yourseffLOL BigGrin If you go into Microsoft office,then into Microsoft picture manager you con resize your photos use 800x600 and the photos will appear on your post without being an attachment hope this helps youThumpUp
cal
#15 Posted : 09 July 2011 15:08:39
thanks mwg im really happy whith how its turning out not looking forward to this next bit tho very steep learing curve for me its my 1st model of this type.......as for pics thanks again ill give that a go
#16 Posted : 09 July 2011 15:14:12
You can do it cal ,just take your time and go at your own pace remember its not a race, you will get thereBigGrin
jimbobuk05
#17 Posted : 09 July 2011 16:59:53
Hi Cal,
Your build is looking very good.
I have just finished the last part
of the hull planking and didnt find
it too bad.
Although, I didnt stick to the mag to
the letter. I figured that that part
of the hull is at the bottom, and is
either going to be painted or covered
in copper. SO, I carried on planking
as per the rest of the hull, and just
added droppers as required.
Good luck with it.
Jim
Foz
#18 Posted : 09 July 2011 18:10:33
Your build is coming along nicely there Cal. Keep up the good work and keep those pics coming.
FOz
cal
#19 Posted : 21 July 2011 20:45:04
here my build to issue 39 the galley supports are only dry fitted so far i im quite happy how the planking has turned out even though i did it with out using the book
cal attached the following image(s):
#20 Posted : 21 July 2011 22:22:06
Fantastic job Cal, you should be really proud of what you have achievedBigGrin BigGrin LOL Wink
2 Pages 12>
This page was generated in 2.299 seconds.
