Joined: 26/08/2017 Posts: 2 Points: 6 Location: GA, USA
Looks like I'm a couple fixing nuts short on stage 20 with extending the head frame. What size are the fixing nuts I need to replace?
Thanks in advance.
If you contact US customer services they will send you a free of charge issue of parts which contains the nuts.
You might want to have a look at issue 18, as the screws and nuts for issue 20 assembly were in that pack. Regards Mark Regards Markwarren (Mark) Admin
Markwarren wrote:You might want to have a look at issue 18, as the screws and nuts for issue 20 assembly were in that pack.
Regards Mark Looks like issue 16 contained 10 nuts. Issue 18 just had frame parts and the microphone pieces.
Joined: 11/08/2017 Posts: 13 Points: 39 Location: ||Newcastle Tyne & Wear
Just for reference, I've sized up the nuts and they are 2mm.
