Date took a dive this evening...... Damage isn't as bad as it might have been, still some extra work to do. Just about every glued joint on the cuirass has come apart (slow cure epoxy), plus the crest holder has come off the helmet. I also spotted one yellow tasset lace has pulled out. Otherwise seems OK.
Awww how sad, hope you can make something of it
Hope your repairs go ok. Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hope it all gets back to how it was Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Never good to see something like this and hope it hasn't suffered any lasting damage.... Regards Alan
Oooh that's not good, I hope you can get it repaired okay.
Rank: Semi-Pro Level 2 Groups: Registered
Joined: 10/05/2017 Posts: 78 Points: 240 Location: Honolulu
That's one of my nightmares. Best of luck with the repairs. -Russ
Rank: Pro Groups: Registered
Joined: 22/12/2015 Posts: 246 Points: 776 Location: Birmingham, AL, USA
Hope all repairs go well for you. I worry anytime someone starts trying to touch mine! Didn't you say you wanted to try some modifications? Tom
Oh heck, I can imagine how you felt after finding this Hope you can recover it
Thanks for the kind thoughts.
I've started sticking the cuirass parts back together, I'll do a bit each day. If I don't it might get left altogether..
