11 Pages «<891011>
1/24 london diorama Options
#181 Posted : 28 August 2017 22:08:24
Very nice work Ken, lovely progress...Cool Cool
kpnuts
#182 Posted : 02 September 2017 18:51:30
Hi all more done on the theatre I'm contemplating adding lights above the STALLS and upper CIRCLE doors, unsure yet soon have to actually start the base as nearly all the car models done, still a long way to go though all the street furniture, which reminds me of another problem, I was going to have all the buildings and fountain removable to make for easier storage as this thing will be huge but what to do about the traffic lights and whatnot.
That is going to be one very big problem.
#183 Posted : 02 September 2017 19:04:17
Excellent work on the theatre Ken.
Cool Cool Cool Cool
I`m sure you`ll come up with an answer to you`re problem.
#184 Posted : 02 September 2017 22:25:01
Theatre looks great Ken Cool
kpnuts
#185 Posted : 30 September 2017 19:15:49
Hi all I need some help here I bought some printer transfer paper to make my own decals I've printed off some police decals for the range rover. The ink seems to not soak into the paper (almost like rain on gloss paintwork) the first pic is the best of 6
Also the decals when applying them are very stretchy
I think the decals won't notice when the car is applied to the dio but I would like to know where I'm going wrong.
#186 Posted : 30 September 2017 22:20:20
Hi Ken, I had a similar problem when printing some photographs onto glossy paper. It would take an age to dry and the ink colours would run into each other blurring everything. The problem was solved by ensuring the correct paper is selected within the printer settings. Once I'd done that everything printed perfectly.... Check your printer settings.... Hope this helps...
#187 Posted : 30 September 2017 22:27:45
I was about to reply but Alan has said it all for meBigGrin It's the printer settings, the printer is laying down too much ink as if it were absorbent paper but the settings may have an option for transfers as well, if not set to glossy.
kpnuts
#188 Posted : 30 September 2017 22:40:42
Thanks guys
#189 Posted : 01 October 2017 12:41:45
Hi there Ken.
I've had exactly the same problem with some decal transfer sheets myself. It does, as the others have said come down to the printer settings. The earliest waterslide transfer sheets said to use top quality photo settings but I've noticed on my last sheet instructions it said "no need to adjust printer settings" My advice would be to start on the lowest quality setting and work up from there.
I have also found some inconsistencies with third party (ok, the cheapest!) inks as well, some will print fine on one type of sheet but crackly on others!Blink
If you are using some print program (I use a 17 yr old Corel Print House) I would also suggest lining up the designs along the top edge of the page, that way after printing you can slice off the designs and put the decal sheet back in using up less of the sheet each time - yeah, I'm a cheapskate!BigGrin
Best of luck and I've just sent off for some more white backed decal sheets myself for the Pups! (I've only got some clear stuff left!)Crying
kpnuts
#190 Posted : 08 October 2017 17:32:29
Hi all nearly finished the range rover next up will be the transit van, I've still to make the police sign for the roof and assorted sundries like the wing mirrors and wipers got loads more work to do on the buildings not even started any street furniture I'm hoping the finished dio will be an impressive site. I've realised I've got to make loads of figures for the street as well (not something I'm looking forward to. I reckon I must have been on this one for a yr by now and I can easily see it taking that long again.
#191 Posted : 08 October 2017 17:57:45
Looking really good Ken, nothing wrong with taking you time.
#192 Posted : 08 October 2017 18:47:50
Another good looking addition to the dio Ken Cool
kpnuts
#193 Posted : 11 October 2017 18:43:18
Hi all well I've nearly finished the cops car so I thought it was time to start the robbers van, it's going to be my favourite style old and beat up.
I wanted to show the scrapes and scratches on the bed of the van so I thought I would use the same method I used for the dent on the Honda tank and the dent in the fender of the traction avant.
I covered the floor pan with foil.
Sprayed it with the body colour then stained and scratched through to the foil.
I've started scruffying up the body.
Tried the floor pan in the body to see the effect
I may go further with the wear and tear on the transit, a few dents or maybe more rust but I'm happy with where it's going at the moment.
kpnuts
#194 Posted : 17 October 2017 19:37:50
Hi all well I've dirtied up the bottom and started ageing the interior of the transit I think it's a great little kit although I would have liked a full engine more.
#195 Posted : 17 October 2017 22:35:06
Coming on nicely Ken, great getaway vehicle, or not!!
#196 Posted : 17 October 2017 23:13:58
You're skills are certainly top notch when it comes to the old and beat up look Ken, all looking fab....Drool Drool .. Very well done....
#197 Posted : 17 October 2017 23:33:05
Loving the old Transit.
Cool Cool Cool
See loads of these old work horses when I lived in the east end of London.
Coming on well, keep up the good work.
Sticky Wickett
#198 Posted : 18 October 2017 09:59:11
That battered, old transit looks the business!Cool. Great work Ken!BigGrin
Phil W.
#199 Posted : 18 October 2017 10:21:58
Coming along nicely Ken BigGrin that transit has seen better timesBlink well doneDrool regards PhilCool
kpnuts
#200 Posted : 18 October 2017 10:42:41
Thanks for all the kind replys guys hopefully be adding some humour to it tonight if i get time. Im really enjoying this bit of the dio.
11 Pages «<891011>
This page was generated in 0.222 seconds.
