Bluenose build Options
#1 Posted : 04 September 2017 00:33:12
BigGrin Hi
Firstly welcome to the forum and enjoy your build.
Go ahead and stain your deck then use a matt varnish to seal it, the deck furniture will fix to this surface when you get to placing it. See explanation below:-
A matt varnish gives a finish like sandpaper that will not reflect light so well with troughs and ridges that break up the light reflection giving that dull look this gives any glue used a grab to adhere too. Gloss varnish gives a smooth finish that reflects light well and has no grab as it is smooth.
Marcallain
#2 Posted : 04 September 2017 00:40:00
Rank: Beginner Level 3
Thank you for your reply I was worried that it would be difficult to glue the deck furniture over the varnish.
Would you need to use CA glue?
Completed Build: Bluenose
Current build: Pegasus
#3 Posted : 04 September 2017 00:42:01
Welcome to the forum. BigGrin
I look forward to seeing your build of the "Bluenose"
Cool Cool Cool Cool
As for posting pictures the link below should help.
Posting Pictures
Happy Building
#4 Posted : 04 September 2017 09:11:34
Welcome aboard, look forward to seeing your build come together.....Cool Cool .. If it's help you need then you are certainly in the right place, lots of experienced ship builders here ready to assist....Cool Cool
Marcallain
#5 Posted : 04 September 2017 20:21:48
Thank you Alan
Marcallain
#6 Posted : 04 September 2017 20:23:06
Cool Cool Cool Cool
Posting Pictures
Happy Building
Thank you Derek
#7 Posted : 04 September 2017 21:06:26
BigGrin Hi I would use a medium or gel type super glue applied with a tooth pick or such likeCool
