13 Pages <12345>»
Schlachtschiff Scharnhorst 1:200 (69/140) Options
#41 Posted : 06 September 2017 15:48:25
looking good.Is the turret plastic or resin?
greyhawk
#42 Posted : 06 September 2017 17:30:41
#43 Posted : 06 September 2017 17:45:45
Looking very nice indeed.
I think they picked a nice ship to do as a partwork.
Hope it continues well for you.
#44 Posted : 06 September 2017 19:39:54
BigGrin Hi Greyhawk looking good and nice work, By the way the square boxes you fitted to the turret are range finder housings. You should get some etch at some stage that will fit on the front face and have a sliding door on it which was opened when the range finder was in use.Cool
#45 Posted : 06 September 2017 20:08:50
Great progress on the hull structure BigGrin looks a nice kit so far.
greyhawk
#46 Posted : 07 September 2017 01:27:24
Those are the ones off to the sides, yes. You can see the doors in my issue 2 update (and next wednesdays update). The difference with "Bruno" are the two little humps on the rear upper back which look like balls of cloth tied up neatly.
#47 Posted : 07 September 2017 10:28:57
I do like this kit so farDrool can`t wait for the plankingDrool great jobBigGrin regards PhilCool
greyhawk
#48 Posted : 07 September 2017 13:11:14
Unfortunately the planking is still a ways off. Naturally everyone is assuming we would start planking now but this kit apparently handles things a bit differently.
#49 Posted : 07 September 2017 18:25:08
What, no planking next!!! that is a surprise.
Great progress love this ship watching with anticipation
J
greyhawk
#50 Posted : 13 September 2017 08:27:18
Scharnhorst Issue 10
Photo etch is added to the second 28cm gun turret and the barrels are test fitted
Both 28cm guns done so far side by side
#51 Posted : 13 September 2017 08:54:19
Guns look great... nice work....Cool Cool
#52 Posted : 13 September 2017 13:01:14
Those gun turrets really are excellentDrool regards PhilCool
#53 Posted : 13 September 2017 19:27:35
Looking nice so far, good job with the photo etch Cool
#54 Posted : 13 September 2017 20:40:57
The turrets look great, nice work with the etch detail.
greyhawk
#55 Posted : 20 September 2017 19:17:42
Scharnhorst part 11: Every 4th frame is doubled up with 4 support parts each. This will make it easier to lay down the first planking (which is still a ways off). It is now that one will see if one worked cleanly enough while putting together the hull structure. Any dried glue will interfere with placement of the supports.
One of the Youtube model builders doing this kit will have a lot of "fun" with this as he tends to drench his models in glue until they look somewhat akin to dripping candles.
daffy09
#56 Posted : 20 September 2017 23:52:50
Good work Greyhawk, nice to see the hull in its entirety. Those guns look good as well and the PE looks to be very good quality. Look forward to next update.
Happy building
David
greyhawk
#57 Posted : 04 October 2017 10:26:42
Back on track with the Scharnhorst after a quick bout of delivery problems.
Scharnhorst issue 12:
Now usually at this point we would start planking the hull, but this kit does things a bit differently, so instead we start building the stern deck structures. I guess they want to get the easy stuff out of the way first.
daffy09
#58 Posted : 04 October 2017 10:49:26
Hi Greyhawk
That's a different way of doing things. The build is coming along nicely now, look forward to next update
Happy building
David
#59 Posted : 04 October 2017 11:11:39
great to see more on thisDrool BigGrin i do hope this comes to the uk Confused regards PhilCool
greyhawk
#60 Posted : 11 October 2017 17:04:03
Scharnhorst issue 13.
More parts are added to the aft deck structure. Little tabs on the bottom slot against the hull support frames and keep the deck structure in alignment.
Guest (17)
13 Pages <12345>»
This page was generated in 3.322 seconds.
