106 Pages «<5960616263>»
Sticky Wickett
#1201 Posted : 01 September 2017 11:07:48
tigerace wrote:
I think you have little Elfs coming in a night to do the rivets LOL LOL LOL great work as always Phil Drool BigGrin regards PhilCool
HahaLOL If only Phil!BigGrin Wouldn't that be great to wake up and all the riveting was done!
Thanks for looking in Phil!BigGrin
Phil W.
TIMBERWOLF
#1202 Posted : 02 September 2017 07:36:26
verry nice job building this submarine, I had like to build it to, but it never come out in the netherlands.
#1203 Posted : 03 September 2017 19:02:05
Looking fantastic Phil. hope you have a good holiday. IanBigGrin
Sticky Wickett
#1204 Posted : 04 September 2017 07:33:09
ModelMania wrote:
Fabulous work as always Phil. I love the way that you are going to the greatest lengths to incorporate every possible detail and I think you will be massively rewarded for your efforts in the finished model - it is going to be stunning!! Drool Drool
Have a nice (and relaxing) holiday. Well deserved.Cool ThumpUp
Thanks for looking in Kev.Cool Your comments are always appreciated.
Phil WBigGrin
Sticky Wickett
#1205 Posted : 04 September 2017 07:35:32
Thanks for looking in Timberwolf.Cool
Phil WBigGrin
Sticky Wickett
#1206 Posted : 04 September 2017 07:36:50
Thanks for looking in Ian!Cool
Phil WBigGrin
#1207 Posted : 12 September 2017 13:31:28
Hi Phil i wonder if you have seen this deck gun ? regards PhilCool
https://www.modelhobbies...u552-648327-p-69427.html
Sticky Wickett
#1208 Posted : 13 September 2017 09:29:27
[quote=tigerace]Hi Phil i wonder if you have seen this deck gun ? regards PhilCool
https://www.modelhobbies...552-648327-p-69427.html[/quote]
Hi Phil,
Thanks for sending the link!Cool Unfortunately it's an 8.8cm gun which featured on early U-boats including U552 [Trumpeter model] and U96 [Hachette model].
In 1942 the admiralty ordered for them to be removed as they proved too unwieldy to use accurately at sea. My build [U230] does not have this gun fitted, instead it has two, twin barrelled 2cm guns on the upper 'wintergarden' [area behind the conning tower] and a 3.3cm gun on the lower 'wintergarden'.
Thanks again for the useful info!BigGrin
Phil W.
#1209 Posted : 13 September 2017 12:16:18
No problem PhilBigGrin hope you had a good breakCool regards PhilCool
Sticky Wickett
#1210 Posted : 14 September 2017 21:49:29
Well i'm back from my hols and back on the boat. A slow start this week, always the way when I've been away, but more rivets have been laid on the stern section .
The attached photo shows the start of laying the vertical rivet strips starting at the stern , starboard side.
Sticky Wickett
#1211 Posted : 14 September 2017 21:50:29
Continuing forward along the starboard side.
Sticky Wickett
#1212 Posted : 14 September 2017 21:51:59
Further forward with the vertical rivet strips.
Sticky Wickett
#1213 Posted : 14 September 2017 21:55:21
More vertical rivets strips laid on the starboard side. I decided to stop when I reached the end of the free flood holes as this seemed like a suitable point to close this section out. I will carry on with these along the rest of the hull once the stern is completed.
Sticky Wickett
#1214 Posted : 14 September 2017 21:56:03
Rivets laid around the starboard exhaust plate.
Sticky Wickett
#1215 Posted : 14 September 2017 21:57:38
In the same manner I started the port side vertical strips, again, using the end of the free flood holes as a marker for the start of this section.
Sticky Wickett
#1216 Posted : 14 September 2017 21:59:28
Working aft on the port side stern.
Sticky Wickett
#1217 Posted : 14 September 2017 22:01:30
Completion of this section of the port side vertical rivet strips.
Sticky Wickett
#1218 Posted : 14 September 2017 22:02:29
Riveting around the edge of the port exhaust plate.
Sticky Wickett
#1219 Posted : 14 September 2017 22:03:57
The next section of vertical rivet strips marked out in pencil on the port side of the stern.
Sticky Wickett
#1220 Posted : 14 September 2017 22:04:56
Starting the marking out of rivet strips on the starboard side of the stern.
This page was generated in 2.861 seconds.
