Walter That looks really neat. A lot of skill putting this part of the ship together i can see but your end result is well worth the time you put in. Happy Modelling
Very nice update Walter, all looking good.... Regards Alan
Nice work Walter. Will be here soon and look to try this.
Great comeback walter. doing a smashing job. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Thanks for the nice comments! Just a small update this time - i finished the painting on the starboard side and added the big knightheads as well as the gangboard pillar frame.DaDokta attached the following image(s): Greetings, Walter
Looking good Walter Al
WTG, looks great. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Well done Walter, looking good..... Regards Alan
Lovely paint work there
Thanks guys!
I always wonder if anyone can see the pics i´m uploading - because when i look at my posts i often cannot see any of them. This is in other people`s threads as well.
Anyway - i painted and added those side-panels of the beakhead.DaDokta attached the following image(s): Greetings, Walter
Hi Walter, your pics are being seen and if you do a page refresh this normally resolves the issue.... Another very nice update on your build, looking great.... Regards Alan
 looking good Walter Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
She looks great Walter..Love the paintwork!! Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Thanks guys! On it goes with the first cathead. I carved three slots instead of two. The paintwork was a bit fiddly.DaDokta attached the following image(s): Greetings, Walter
Walter That looks very good. Care will be needed now when moving the model to make sure bits such as this do mot get damaged or knocked off. Love the neat paintwork. Happy Modelling
Thanks Tony!
Here`s an update of my weekend`s work.
I painted and attached the second cathead.
Then painted and mounted the rails to the beakhead.DaDokta attached the following image(s): Greetings, Walter
I added small wood carvings to blend the parts into each other (is this right english?). All gaps were filled and sanded.DaDokta attached the following image(s): Greetings, Walter
Then it was painting again and again and again...
I love those elegant lines!DaDokta attached the following image(s): Greetings, Walter
So the starboard side is done! Finally i wanted to show you a picture where i put the real bow on my i-pad beside the model.
Looks quite similar!DaDokta attached the following image(s): Greetings, Walter
 Rank: Semi-Pro Level 1   Groups: Registered
Joined: 01/10/2015 Posts: 62 Points: 179 Location: netherlands
Guest (28)
