6 Pages «<3456>
Delboy`s C57 Options
#81 Posted : 18 September 2017 19:54:38
Love it Derek, looks amazing....Love Love
#82 Posted : 19 September 2017 16:17:42
Looks great Derek.
I also lost paint from the hand rails, like you say though easy enough to touch up Cool Cool
#83 Posted : 22 September 2017 05:48:09
Hi All, BigGrin
Thanks for all the interest shown.Cool Cool Cool
Have an update for you.
This update is the start of pack 7, beginning at stage 47.
First thing is to extend the right hand running board. As before lose fit the brackets, fit the base board and the running board, then tighten the brackets. Pic 1
Following on fit three sandspreader tube fasteners (one arrowed right of next picture, two slightly hidden by cooling tube). The right cooling tube has a joint and two mounting brackets added, before it`s fixed through and onto the running board. (The two other sand tube fastners are just visible behind the cooling pipe). Pic 2 The sand tube fasteners are fitted to the other side later, visible but fitting not shown in this diary.
That concludes stage 47, more soon. BigGrin
#84 Posted : 22 September 2017 06:21:52
Following on, stage 48 builds the compressor and fits it with a bracket to the left hand side of the model.
The compressor consists of six easily assembled parts, shown in pic 1 and fitted to it`s bracket and the engine in pic 2.
In stage 49, you first fit an inspection lid to the running board, part of it arrowed to the left of the next pic (it`s a flat plate with a locating lug fitted to the running board)Blushing missed a full pic.
This followed by the left hand cooling tube in similar fashion the the right one. All shown in pic 3.
Next fit the reservoir tank under the left running board after fitting the cooling pipe in the end, attach to the running board with two screws.pic 4
Lastly, for stage 49 fix the down pipe from the cooling pipe with a connector and fix into the compressor.
That concludes stage 49 and this update.
Happy building
#85 Posted : 22 September 2017 09:13:12
Looking soooo good Derek, beautiful work.....Cool Cool Drool Drool
#86 Posted : 22 September 2017 12:40:58
Another great update Derek BigGrin looks more impressive every update.
#87 Posted : 22 September 2017 12:45:49
Lovely work Derek, coming on great.
#88 Posted : 24 September 2017 16:17:53
Hi All,BigGrin
Thanks again for the views and support, most appreciated. Cool
So it`s now stage 50 and the half way point of this build.Blink
In stage 50 you build the water pump. Pic 1
Then fit the pump to the right hand side via a bracket. Pic 2
Onto stage 51:
Fit the right hand inspection lid. Pic 3
Fit the right air reservoir. Pic 4
Fit the air cooling tube. Pic 5
Lastly for this update, stage 52:
Add the next running board. Pic 6
Add to that the oil pump box. Pic 7
Finally add the coupling gear. Pic 8
Well that`s all for this update, just three more stages till the end of Pack 7. Got to download and edit some pics, then I`ll finish off pack 7.
Be back soon. Blink
#89 Posted : 24 September 2017 17:11:10
Very nice update on your build Derek.
#90 Posted : 25 September 2017 15:53:17
Hi All, BigGrin
Thanks Tony for your comments and all who have looked in. Cool Cool
This update is the last for pack 7 and until pack 8 arrives and I get some more built. Confused Hmmm - May have to start the E-Type, but don`t tell anyone Eh. LOL LOL LOL
So, stage 52 finished and now onto Stages 53 - 55.
Stage 53 sees the last running board fitted along with the Oil pump box and Boiler tank. Pic 1
That`s followed by the Fire hydrant and water supply pipe. Pic 2
Stage 54: Has two sections, the first of which I`ll be doing at a later time. That`s putting the connectors onto the lamp wires.
Second part is the fitting of the main cab frame. Pic 3
Stage 55: First thing to do is make up the cab floor. Pic 4 Then fit with four brackets.
Followed by the floor edging. Pic 5 close up
Pic 6 cab overview
So that`s the end of pack 7, see you soon with the start of pack 8.
#91 Posted : 25 September 2017 18:37:02
BigGrin Looking good DerekCool
#92 Posted : 25 September 2017 20:26:09
Yet again more lovely work Derek BigGrin Cool
#93 Posted : 25 September 2017 20:34:36
Great work Derek, certainly looks like you are enjoying this build.
#94 Posted : 17 October 2017 13:52:23
Hi looking good coming along very nicely cheers MickBigGrin
#95 Posted : 09 January 2019 12:56:20
Well, time for a long awaited update.Blushing
Have quite a bit done so will update in sections from time to time.
So onto stage 56:
This involves making up the two seats for the cab and fitting them along with the Brake Valve and Water Injector Pipe. Note that the Brake Valve needs orientating so the levers are facing the correct way.
#96 Posted : 09 January 2019 19:47:06
Stage 57
Two jointing plates are are screwed to the top of the left-hand cab wall and the cab corner roof plate is then fixed to these plates.
An outer window frame is glued to the outside of the cab wall and the assembled sliding window fixed to the inside.
A vent plate is then fixed to the lower cab wall.
The last thing to do for this stage is fit the window eave above the window on the outside of the cab wall.
#97 Posted : 09 January 2019 22:13:51
Nice to see you back on this again Derek, love this kit.
#98 Posted : 09 January 2019 22:54:30
BigGrin Comming together nicely and looking goodCool
#99 Posted : 09 January 2019 23:26:46
Looking fab Derek, great to see you working on this again....Drool Drool
#100 Posted : 10 January 2019 22:27:34
Hi Derek ,good to see you back on this,looking good ,cheers mick.BigGrin
Guest (13)
6 Pages «<3456>
This page was generated in 0.637 seconds.
