Really nice job with the painting, its given it a gorgeous weathered look
 Rank: Pro  Groups: Registered
Joined: 26/01/2014 Posts: 119 Points: 343 Location: Newcastle
very nice, I only hope mine ends up half as good as that when I get around to working on it Current builds: HMS Victory, hachette black pearl, DC-3, R2-D2, Millennium Falcon
 Nicely done and something to be proud of Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 06/08/2015 Posts: 276 Points: 817 Location: Monrovia, Ca
Thank you, everyone for your kind comments. This has been one of the most enjoyable projects I have ever done. I definitely picked up a lot of ideas and knowledge on how to go about how to paint the model from this forum. Regards, Stephen Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Hi Everyone, More Bottom Hull Parts Using the same paint method as mentioned before, I worked on the remaining thrust vector plates and the front hull plates that house the landing gear. The base coat painting was all done to each part before being added to the main framework. Weathering was done once the pieces were attached so that I could match to weathering better to what I had done previously. Here are some photos of the progress. Regards, Stephen scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Hi Everyone, Bottom hull comes full circle. After many months with a half completed framework for the bottom of the hull, I finally have all the parts to finish the framework. We also get the much anticipated ramp. I did wait to attach the motor for the ramp until much later. I didn't want to put any undue stress on it as I worked on the build. Here are some photos of how things went. Regards, Stephen scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
