stage43 (pack11) Options
wolfy
#1 Posted : 21 September 2017 16:54:40
Rank: Newbie
Hello! I got pack 12 from my H1 build but i got to the stage where i need to use the spare silicone tube i got left over from stage 43...The problem is i can't find it... Now i am trying to replace that with other tube but i don't know what size it was.I know that in stage 43 you get a length of silicone tube from witch you cut 2 pieces of 11cm but what i need to know is how long is that leftover piece or how long was the entire tube length. Anyone here can help me with an answer? Cheers!
#2 Posted : 21 September 2017 18:25:46
The silicone tube is atandard fuel tube which is sold by any RC car or model aircraft shop or online. Failing that, contact c/s for a replaceemnt of the parts stage. Its exact length is unimpotant just as long as it connects between the two points without being kinked or tight in length. Simply run a length between the two points and cut with a 3cm excess, then trim if need be.
This page was generated in 0.080 seconds.
