Think you're doing a great job with this Baz, the framing looks spot on....  .. Very well done, look forward to seeing your next update.... Regards Alan
Interesting to know that the plastic mouldings are part of the kit Baz, thanks for that and I agree, it'll be a real shame to cover up the frames .... but think how nice she'll look with all of those polished aluminium panels fitted?!
Kev
Looking good, you're doing a great job.
 Rank: Pro  Groups: Registered
Joined: 26/01/2014 Posts: 119 Points: 343 Location: Newcastle
Thanks for the comments the tail section is has a lot of pieces compared to the rest of the frame. I filed a lot of material from the metal parts but still not happy with the fit so will need to add filler and shape them. Bazholding attached the following image(s): Current builds: HMS Victory, hachette black pearl, DC-3, R2-D2, Millennium Falcon
Hi Baz, Looking good. Couple of things to remember. Make sure that all the stringers when fitted are flush with the wooden frames (gives a better surface to fix the plating to) and when fitting the metal shaped pieces, use a scrap of plating material as a guide to make sure that the metal parts are set at the correct level. I acheived this by laying the scrap of plating material on the frames next to where the metal parts are to be fitted, then fix the metal parts level to the plating. Hope this helps, keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
for the nose section I tried to make the stringers as flat as possible then give the entire piece a light sanding over the stringers. good tip using a scrap of the covering though, thanks. I wasn't happy with the fitting of the metal parts and I was tempted to remove them and try again but after fitting the rest of the wood parts I dont think I can get a better fit. Bazholding attached the following image(s): Current builds: HMS Victory, hachette black pearl, DC-3, R2-D2, Millennium Falcon
Hi Baz, That looks pretty good. You have a little bit of scope with the plating to make some minorr adjustments for fit to the metal parts, so should be Ok. The metal parts are quite soft, so if "essential" you can file (very carefully)a bit of material away. Do be very gentle in this approach or you may alter the shape noticeably. I would wait until you have all the stringers fitted and then recheck the fit of the plating, using the piece of scrap as before. Keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice work Baz, very neat and tidy - well done.
Kev
A build that requires patience and you have plenty of that Baz, all looking great..... Regards Alan
Thanks everybody I have now painted a base coat on the last of the wooden parts for the wings, once I have put those together I’ll start fitting the stringers onto all the sections and complete any sanding/shaping works that are needed Current builds: HMS Victory, hachette black pearl, DC-3, R2-D2, Millennium Falcon
Really coming along Baz  great work  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Really nice work Baz, keep the updates coming
had a few problems with the wings, first a few pieces delaminated then i started to put the left wing together backwards. oops woodwork for the left wing is now all complete. i used 4 magnets to hold crew/radio room in place. it holds well but not strong enough so I have drilled an another 4 holes. think i will use the top 2 for locator pins and the bottom 2 for magnets. Bazholding attached the following image(s): Current builds: HMS Victory, hachette black pearl, DC-3, R2-D2, Millennium Falcon
That all looks very nice and you have put it all together so neatly. Happy Modelling
Very nice work, it's really starting to come together.
Great update Baz  looks very impresive even with one wing on  looking forward to your next update  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Well done Baz, looks good. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looks excellent, nice work. Mark Regards Markwarren (Mark) Admin
Lovely work again Baz and very nice to see one of these progressing beyond the early stages. It looks very cool to see a full fuselage with wings attached and no skin applied, you're making a great job of this!
I particularly like those frontal photos, well done.
Kev
Looking impressive Baz  your doing a great job. Al
