4 Pages «<234
The Black Snake, Queen Victoria's Ironclad, HMS Warrior 1:100 scale Options
#61 Posted : 28 May 2017 05:23:43
Tomick wrote:
jase wrote:
News flash
I have just been informed by the HMS Warrior Trust that they will be releasing a Haynes manual for the Warrior. The book is due out in about 2 months
They must have told you last Laugh - it's been on the Haynes website for a month or so at a pre-order special price and is out in July
https://haynes.com/en-gb/hms-warrior-manual
I am ssualy last to know most things 😂😂😂😂😂
#62 Posted : 17 September 2017 17:53:30
Hull frames are now complete other than some parts for the stern. the hull has now been faired, there is significant fairing required at the bow and a little at the stern but not much to do all in all.
I have put the first hull strip in place. This model is single planked so these will form the outer hull. The first one to go on is the stern strip that terminates at the stern gallery. Two of the ribs have lugs that locate in rectangular holes in the ply hull strip. One of my lugs did not line up with the hull strip being out by 4mm. I spent quite some time checking everything but cannot see any issues with the ribs alignment. I have settled with widening the lug hole. (you can see in the photo below the widened hole is the stern lug)
Once in place I have checked its alignment with the deck and all looks spot on so I am happy, for now.
jase attached the following image(s):
daffy09
#63 Posted : 17 September 2017 19:16:11
Nice going Jase. It had slipped my mind that you were building this one. Look forward to your next instalment.
Happy building
David
#64 Posted : 17 September 2017 20:48:43
Happy building
David
Its my reward for finishing Pickle BigGrin
Sticky Wickett
#65 Posted : 19 September 2017 15:20:54
This model is going to be HUGE Jase!Blink Good work so far!Cool
Phil W.BigGrin
#66 Posted : 19 September 2017 15:30:44
Glad to see you back on this JaseBigGrin looking forward to your progressCool regards PhilCool
#67 Posted : 24 September 2017 16:59:12
Many thanks for looking chaps...
pleased to say the fit of the other parts was flawless. the biggest challenge is the shape of the bow but plenty of clamps help get that correct. There is a small part of the ply yet to be formed these need to be bent and meet in the middle I will do this using steam when the other side is installed.
With the for hull sides in pieces in place I fitted the remaining ply parts at the stern.
The irony of this kit is that the real ship was clad in Iron only up to deck level, traditional wood planking being used above the upper deck. the kit is single planked but above the deck is strips of ply. would have been nice to have plank on Frame above the deck I think.
some pics of progress
PS. if anybody goes to see the new film Victoria and Abdul (which I can recommend its great). you may spot a CGI modified HMS Warrior, her masts and bulkhead shape is very unique and easily recognisable.
#68 Posted : 24 September 2017 20:03:00
BigGrin nice update Jase looking forward to starting mine so will be following with interest Cool
Martyn
daffy09
#69 Posted : 24 September 2017 20:11:44
I'm liking this build very much Jase. It will be interesting to see the bow take shape, that's quite a lot ply to get into shape. Look forward to your next update.
Happy building
David
#70 Posted : 25 September 2017 07:44:19
Taking nice shape, though surprised it's not in a keel jig as there's a lot of length in the keel and over hang either side of the keel clamp, which will allow flex when setting the ply and hull planking.
#71 Posted : 25 September 2017 09:16:18
She's taking shape nicely Jase, great to see....Cool Cool
#72 Posted : 25 September 2017 10:19:12
Nice work JaseBigGrin coming along a treatDrool regards PhilCool
Sticky Wickett
#73 Posted : 25 September 2017 10:28:56
Nice work so far Jase!Cool Will be following.BigGrin
Phil W.
#74 Posted : 25 September 2017 20:45:46
Many thanks everybody for taking the time to leave a comment.
@ Tomic, A build board is being used for construction but due to its large size I am having to move it to take pics. Thanks for the advice, certainly don't want a banana shaped WarriorBlink but all good so far.
#75 Posted : 02 October 2017 15:06:45
Hi Jase.
Looking very good. Look forward to seeing more of this one.
Ian Cool BigGrin Drool
4 Pages «<234
