Joined: 27/09/2017 Posts: 2 Points: -4 Location: Ipswich
Am I the only person having real problems with fitting the "B" spokes in part 5, have treid everything to fit the first one and all I end up with is a very bent spoke, (due to trying to get it through the correct gapp in the earlier spoking) and the feeling that my car may have to be displayed with no wheels on it? Is there a "knack" to getting "B" spokes fitted or is it just down to brute force?
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,865 Points: 17,747 Location: ipswich
There are a few guides on the forum. There's one here: http://forum.model-space...spx?g=posts&t=23122
All the best.
Welcome to the forum tyegerjak, sorry to hear your having issues with your wheel. Hopefully the link to the wheel tutorial that Roy has previously given has helped you to get it sorted.
However if this is not the case can you post a photo of your wheel to help identify the problem.
 Rank: Semi-Pro Level 2 Groups: Registered
Joined: 13/02/2017 Posts: 77 Points: 230 Location: Liverpool UK
Hi tyegerjak They are stubborn beasts. They seem to turn the wrong way just before they need to go through the hole in the spokes. They will go through though. I've pm'd the method I used. I hope it's some help to you. Kind regards. Happy modelling
Alec
