106 Pages «<6263646566>»
Sticky Wickett
#1261 Posted : 22 September 2017 11:23:42
Beautiful work once again Phil, well done....Cool Cool
Thank you Alan. Your comments are always appreciated.Cool It's a long job and the finish line is just about in sight.BigGrin
Phil W.
Sticky Wickett
#1262 Posted : 22 September 2017 11:25:50
tigerace wrote:
At last you`ll be able to get a good nights sleepLOL great work as all ways PhilBigGrin regards PhilCool
Thanks Phil!Cool The riveting isn't complete yet, but the end is in sight. I'll keep chipping away at it for the next three weeks and all will be done.
Phil W.BigGrin
Sticky Wickett
#1263 Posted : 22 September 2017 11:27:41
ian smith wrote:
Hi Phil.
Cool Looking fantastic. The rivets really finish off the look of the hull. BigGrin Drool Ian
Thanks for looking in Ian!Cool What with seamless welding and acoustic panelling these days, the rivets certainly place the boat within a period of time in history.
Phil W.BigGrin
Sticky Wickett
#1264 Posted : 22 September 2017 11:33:58
Markwarren wrote:
Nice update Phil, great work, it's been a long tunnel.LOL
Thanks for looking in Mark!BigGrin You're not wrong there. I think the thing to do and it works for me, is to work on small sections and concentrate only on those. To take everything in, the enormity of the task can seem over- whelming.
Phil W.
Sticky Wickett
#1265 Posted : 28 September 2017 21:35:19
This weeks update focuses on the completion of the rivets and weld lines on the stern of my U230 U-boat build log.
The attached photo shows the next section riveted on the underside of the stern, starboard side.
Sticky Wickett
#1266 Posted : 28 September 2017 21:38:44
This photo shows the rivets being continued on the under starboard side and also weld lines added to the hull and around the prop shaft housing.
Sticky Wickett
#1267 Posted : 28 September 2017 21:40:11
Similarly, the under port side was riveted in the same section.
Sticky Wickett
#1268 Posted : 28 September 2017 21:42:27
Continuing forward I added further rivets and the hull and prop shaft housing weld lines.
The attached photo shows an under side shot showing the weld lines on both the port and starboard prop shaft housings.
Sticky Wickett
#1269 Posted : 28 September 2017 21:44:14
Continuing forward I added rivets to the starboard underside.
Sticky Wickett
#1270 Posted : 28 September 2017 21:47:14
I carried this section around the hull.
Sticky Wickett
#1271 Posted : 28 September 2017 21:48:37
Back up round the port side.
Sticky Wickett
#1272 Posted : 28 September 2017 21:51:12
Adding weld lines where the hull meets the starboard saddle tank.
Sticky Wickett
#1273 Posted : 28 September 2017 21:52:53
All weld lines and rivets complete on the stern, starboard side!BigGrin
Sticky Wickett
#1274 Posted : 28 September 2017 21:54:15
This photo shows the weld lines added to the port side hull.
Sticky Wickett
#1275 Posted : 28 September 2017 21:55:25
All rivets and weld lines complete on the stern, port side.BigGrin
Sticky Wickett
#1276 Posted : 28 September 2017 22:08:49
I can't believe it! After 4 weeks the stern section of the boat is now complete! Woop woop!!LOL Blink BigGrin Cool LOL Blink BigGrin Cool Love
Phew! Epic!LOL
Next week i'll be adding weld lines along the length of the lower hull and marking out the rest of the guide lines for the rivets along the mid-ships upper hull, both sides.
The week after that, I aim to add all the rivets to the mid-ships upper hull and weld lines to the saddle tanks.
AT THAT POINT, SHE'S READY FOR UNDERCOAT!!! [cue fanfare].Cool
Thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin
Phil W.
#1277 Posted : 28 September 2017 22:48:15
An incredible display of patience Phil, looks fantastic.....Drool Drool
#1278 Posted : 29 September 2017 07:18:54
Great work Phil, patience and hard work always pays off.
Matk
Sticky Wickett
#1279 Posted : 29 September 2017 09:32:53
Thank you Alan! Cool It's getting there!BigGrin
Phil W.
Sticky Wickett
#1280 Posted : 29 September 2017 09:33:59
Matk
Thanks for looking in Mark!Cool Much appreciated.
Phil W.
Guest (13)
This page was generated in 0.463 seconds.
