planking the stern Options
cal
#1 Posted : 26 April 2011 19:10:29
hi everyone hope all builds are going to plan, ive posted a couple of pics of the stern ive just bent the 1st plank & was wondering have i sanded enough off the back or do i need to sand more
CMB
#2 Posted : 26 April 2011 20:05:11
Hi cal,
I think you need to sand the back so it is flush with the false keel from top to bottom.
CMB
Dontshootme
#3 Posted : 26 April 2011 20:47:19
Sorry cal,you still have a lot of sanding to do,the whole of that area needs to be flush with the false keel.Blink
#4 Posted : 26 April 2011 20:47:53
I concur with CMB, the last frame i.e the area immediately below the transom needs to be sanded level with the back of the false keel cal...
#5 Posted : 26 April 2011 21:52:43
nooooooooooooooooooooooooooooo not enough,I know your right arms tired,but...........................long way to go yet.Flapper Blushing
whoops,sorry just do a bit more.
cal
#6 Posted : 27 April 2011 12:26:57
guess im sanding more then cheers guys on with it now :) must say bending the 1st plank was a lot easier then i was expacting
This page was generated in 0.040 seconds.
