13 Pages «<23456>»
Schlachtschiff Scharnhorst 1:200 (69/140) Options
daffy09
#61 Posted : 11 October 2017 18:27:03
Another nice update Greyhawk
Happy building
David
greyhawk
#62 Posted : 18 October 2017 09:34:49
Scharnhorst issue 14
Work begins on the middle deck structures.
The kit is now 10% done so here's a a look at everything built so far.
Sticky Wickett
#63 Posted : 18 October 2017 09:51:20
Nice progress Greyhawk.Cool Looking good!BigGrin
Phil W.
#64 Posted : 18 October 2017 10:19:59
really looking greatDrool can`t wait to see her plankedCool regards PhilCool
#65 Posted : 18 October 2017 10:34:59
All looking very nice Michael.
Hope all of your planking work goes well for you.
daffy09
#66 Posted : 18 October 2017 11:41:07
Hi Greyhawk
She's coming along nicely now. Looking forward to seeing more soon.
Happy building
David
greyhawk
#67 Posted : 18 October 2017 12:35:45
Whenever that starts. In the previews all we see right now is more work on the deck structures at least until issue 19.
greyhawk
#68 Posted : 25 October 2017 08:58:34
Scharnhorst Issue 15
Added a few additional layers to the middle deck structure. Not very exciting.
What is exciting though (to me, at least) is that two weeks ago I got my hands on an unbuilt partwork kit of HMS Hood (the original UK edition, not the botched German one) at half price. This gives me the unique opportunity to build both cruisers with aspirations of being battleships in sync side by side and have a look at the differences between them and the way they are built up.
So I quickly went on a building rampage and got the Hood built up to issue 15 too (here in the foreground with Scharnhorst in the back). One can readily see the size difference between both ships. The Hood has the option of being made RC capable, so she features an open design with detachable deck structures, making the build so far more complex (165 parts vs Scharnhorsts 118 at this point).
Comparison shots between ships will be made every month.
#69 Posted : 25 October 2017 09:41:09
Another very nice update and great to see the Hood progressing alongside.... all looking good....Cool Cool
#70 Posted : 25 October 2017 10:52:07
Wow you going to have your work cut out for you nowBlink great kit the Hood willDrool look great togetherDrool Drool regards PhilCool
greyhawk
#71 Posted : 25 October 2017 14:02:42
Not really. So far the Scharnhorst is so dumbed down (and continues to be for the next two months at least) that it takes up between 15 to 30 minutes of my week. I DO hope things will pick up in complexity later, but so far it's a rather boring affair.
#72 Posted : 25 October 2017 18:25:31
Cool to see 2 big boats being built at the same time.
#73 Posted : 26 October 2017 08:35:03
Nice to see the progress of both, hood is a long ship by anybodys standards
greyhawk
#74 Posted : 01 November 2017 09:53:27
Scharnhorst issue 16
Those parts of the deck structures that will later be "outdoors" are decked with a thin sheet of lime wood (not quite a veneer though).
You may notice I have only temporarily fitted the side panels in the middle structure. That is because I have found an error with the precut pieces affecting the entire run which will make installation of a piece of secondary armament impossible/awkward in about two years time. Let's see if you can find it, apparently I was the first/only one in Germany to see it. Hachette has acknowledged and is currently discussing whether to replace the panels or have us do the necessary changes ourselves later down the line.
#75 Posted : 01 November 2017 10:09:10
Its coming along well but a shame the kit has errors built in.
Is it anything to do with those 2 triangular pieces were the drilled hole is on an edge?
Hopefully the company will sort a fix out before it progresses much further and becomes difficult to resolve.
greyhawk
#76 Posted : 01 November 2017 10:15:53
It has very much to do with the pre-drilled holes, yes. Not on those pieces but on the lower left you will see a hole that is in an entirely different place than the one on the upper left. The panels should be mirror images of each other though. Funny enough this error is even in the instructions.
#77 Posted : 01 November 2017 11:03:09
Shame about the errorsBlink i`m sure they will fix itBigGrin good progress thoughCool regards PhilCool
Sticky Wickett
#78 Posted : 01 November 2017 11:28:09
With your skills Greyhawk, I'm sure you will find a solution.Cool
Phil W.
#79 Posted : 01 November 2017 19:59:40
Looking good so far Cool shame about the error with the predrilled holes Blink
#80 Posted : 01 November 2017 21:42:45
Would not of noticed that myself so fair play to you for spotting it.
Not quite sure what you might have to fit over the top of that but hopefully you are now in a position to put right any further parts that might ,add to the problem.
13 Pages «<23456>»
This page was generated in 0.213 seconds.
