I have always wanted to build a traditional Scottish wooden fishing boat but have never seemed to get around to it so when I once again saw the plans for this in an advert in Model boats mag I finally took the plunge. The plans are by Sandy Cousins and distributed by Traplet and, as luck would have it, I ordered the plans exactly one week before Traplet publications went into administration. The plans are on eight sheets, one of which shows how to make a working trawl net, which I doubt very much I will be doing. The boat will be built as a working r/c model, my first for many years, but knowing me it will probably sit as a display model until such time as my grandson is old enough to take an interest in sailing her (if he ever does). The model will be 500mm in length with a beam of 150mm. This will be my first fully scratch built hull and as such could be fun. The plans call for the frames to be made from 0.8mm cardboard/pasteboard and the hull plating from 0.4mm cardboard/pasteboard but I decided to make these from 0.8mm and 0.4mm ply respectively. The keel piece is made from 3mm ply. The plans also call for the planking to drawn onto wider strips of 0.4mm ply which are then applied over the plating but I intend to plank the hull with mahogany planking strips applied to the ply plating and well varnished. The interior of the hull framework will be coated with epoxy resin. The first Pic shows the side plan of the boat as she should look when completed. So to start the build. The keel piece was traced onto 3mm ply using carbon paper and cut out with a Stanley knife. I cut out a 3mm wide section where the prop shaft will be fitted and glued 3mm ply strengthening pieces across each side of the cut out, this forms a pilot hole which will then be drilled out to take the prop shaft. A similar operation was performed for the rudder tube. Pic 2 shows the keel held in a keel clamp. The frames are produced as half frames, Pic 3, and there are 24 frames (48 half frames) in the hull. To cut these out I scanned the drawings and then printed the frames out. These were then glued to the 0.8mm ply with photomount and then the individual half frames cut out. The frame number was then marked in pencil onto the ply and the paper removed from the frame. A waterline deck piece, with slits cut to position the frames, is used and this was again traced out using carbon paper – this time onto 0.8mm ply – and again cut out with a Stanley knife, pic 4. A scupper deck runs around the top of the frames onto which the main deck is later screwed down. Pic 5 shows the scupper deck traced onto 0.8mm ply prior to being cut out. The marked square sections are the positions for strengtheners to be glued under the deck where the main deck screws will be located and the four cross sections are temporary stiffeners which will be cut away later. 3mm square strips were glued to the keel at the waterline to support the waterline deck (these can be seen in Pic 2) and I made a couple of supports from scrap plastic card which were clamped to the centre of the keel to temporarily support the waterline deck until some of the frames were glued in place, pic 6. It was now time to start gluing the half frames in place. Each half frame is test fitted in place and any adjustments made before gluing it into place. Pic 7 shows the first few frames being fitted. Well, that’s it for now Graeme pemberg attached the following image(s):
Looks to be a very interesting project. Looking forward to seeing it progress. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Very interesting project Graeme.  Will be following. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
 Looks a nice plan and great start Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks as if you have yourself a very interesting kit Graeme and great to see you're off to a very nice start..... will be following with interest on this one....  .. Good luck with it.... Regards Alan
Hi Graeme Your new project looks like it will translate into a beautiful model, and you're off to a good start. You have a talent for finding interesting builds. Let's hope your grandson does show an interest as he'd be proud to sail that unique boat with his friends. I'm definitely going to be following this diary. Happy building David
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,818 Points: 17,606 Location: ipswich
You should have a peep at an old Scottish TV show: The Vital Spark. A brilliant comedy about an old Clyde puffer and the crew. https://www.youtube.com/watch?v=Q3fRxJIjJ2U
Roy.
Thanks for looking in guys and the comments.
Roy, thanks for the link, I remember the Vital Spark, in fact I think it was repeated on TV a couple of years ago. I must take another look.
Just a brief update, I have now attached all the half frames to the keel and apiece of triangular bead to each side of the keel at the bow to support the hull plating when fitted. I checked the beam measurements at all the frames and compared them to the marked out scupper deck and found some slight discrepancies where the actual beam was slightly wider than the traced deck - probably poor tracing on my part - so I have decided to make a card template first then, when correct, use it to mark out the ply. Graeme pemberg attached the following image(s):
Looking really good Graeme, can see this is going to be a real interesting project to follow..... Regards Alan
Looking good Graeme, you're really getting going with this. Great work Happy building David
Looking very impressive already. Ken's the name modeling's the game.
Thanks for looking in and the comments guys. As I said in my last post, when I test fitted the scupper deck it was short of the edges of the frames in several places. To rectify this I weighted the deck in place, Pic 1, I then measured the discrepancy at each frame position and noted this on the deck, Pic 2. I then placed the deck on a piece of card and drew round it. I then marked the correct positions at each frame and using a flexy curve re-drew the deck outline. This card template was then cut out and test fitted on the hull, Pic 3, and was found to fit correctly. This template will now be used to cut out a fresh scupper deck but that’s for the next update. Graeme pemberg attached the following image(s):
This is going to be a great model to have on the shelf Graeme. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
 Nicely done and great work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
really enjoying watching this come together.Superb work
Neat and tidy build  nice work. Al
Well done Graeme, like the way you are working your way through this one.... Looking great.... Regards Alan
Nice work Graeme, all these things are sent to try us and coming up with a solution shows the skill of a great modeller. Doing well mate. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Great work Graeme  looks quite an interesting project you have  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
