51 Pages «<2223242526>»
DaDokta`s Build Options
#461 Posted : 25 September 2017 09:13:17
Lovely work Walter, its the paying attention to the finer details that make a build special.... You're doing a great job....Cool Cool
DaDokta
#462 Posted : 12 October 2017 08:09:32
Thanks for your nice comments.
In the meanwhile i finished the second cathead and the bow rails.
Also i painted the cathead crowns.
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#463 Posted : 12 October 2017 08:41:47
Very nice update Walter.
Those crowns are so small but painted very nicely. You must have good eyesight and a very steady hand.
#464 Posted : 12 October 2017 17:35:10
Have to agree, that`s very tidy paint work.
Cool Cool Cool Cool
#465 Posted : 12 October 2017 17:49:55
Really nice paintwork
#466 Posted : 12 October 2017 19:13:31
Top notch work Walter, she's looking superb....Drool Drool
DaDokta
#467 Posted : 13 October 2017 09:38:52
Thanks guys!
My next task was the belfry.
Studying the plans i realized that i had to remove the forward lining of the waist we had to attach earlier following the instructions.
Then glued a smaller diameter wood stripe.
I used a 3D-laser cut belfry by shapeways but had to add a few pieces of wood.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
daffy09
#468 Posted : 18 October 2017 08:20:03
Hi Walter
Just caught up with your diary. Lovely work. Those crowns on the catheads make a world of difference - nice touch.
Happy building
David
#469 Posted : 18 October 2017 08:48:32
Another very nice update Walter, all looking great....Cool Cool
DaDokta
#470 Posted : 18 October 2017 09:35:31
Thanks guys!
In the last days i wanted to produce those rails/knightheads right and left of the belfry.
I thought this would be an easy job - well - it wasn`t!!
Some of those little knee-parts were already broken when delivered - the rest of them i destroyed myself when trying to carve those little knightheads at the top. So i had to improvise.
When everything was finally glued on the deck i realized (looking at a picture of the real victory - which maybe i should have done earlier)that the rails should have been positioned higher.
So - not my best work but i hope no one will know except myself.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Sticky Wickett
#471 Posted : 18 October 2017 09:48:20
Great build Walter.Cool Excellent painting!BigGrin
Phil W.
DaDokta
#472 Posted : 19 October 2017 12:17:12
Thanks Phil!
The deck rail at the aft of the waist was next. I deviated from the instructions as there are only two pillars in the mid-section of the rail, also the height is completely wrong.
So i shortened the pillars and put them in the correct positions.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#473 Posted : 19 October 2017 13:57:45
Really excellent build WalterDrool BigGrin any idea when you`ll resume on your U-96 buildConfused regards PhilCool
#474 Posted : 19 October 2017 18:43:27
BigGrin Nicely doneCool
#475 Posted : 19 October 2017 19:11:22
Walter it gets better with each update you post.
Its a really lovely looking model you have yourself there.
#476 Posted : 19 October 2017 22:32:53
Looking good Walter, nice improvisations.....Cool Cool
DaDokta
#477 Posted : 20 October 2017 12:27:22
Thanks for your encouraging comments, guys, which make me very happy - especially as they come from fellow builders whose skill i have been admiring for a long time now!
@Phil
I put the U-69 (and all my other models)aside and promised myself to first finish the Vic!
So it might be a couple of years till i resume those builds!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#478 Posted : 20 October 2017 22:24:48
Always a pleasure viewing your updates Walter BigGrin more good progress from you.
#479 Posted : 20 October 2017 23:56:53
Nice update Walter, coming along superbly.
Chris Cool
DaDokta
#480 Posted : 23 October 2017 06:30:20
Thanks again!
So here is my next update:
I added those hammock nets to the rail before attaching it to the hull (didn`t like the sewing at all - i took several tries to get it approximately right).
Then i added the handrails around the waist - again i deviated from the instructions - running the rails as in the original plans in my books.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Guest (37)
This page was generated in 3.105 seconds.
