Perfecting the Gratings Options
#1 Posted : 01 May 2011 14:39:00
Anybody with the detail packs will know that the gratings in the magazine look quite different to the real things. so here is my attempt at making a more authentic grating as per the pic below
All pictures Authors collection.
This is the medium grating in issues 48 but the principle will be the same for all of them.
I started by following the instructions in the magazine up to step 6. In step 7 i disregard the 2x2 as i have not used them. before making the assembly in step 8 I painted the inside edge of the wood strips walnut brown.
To make the shot rack i used some spare 2x5 left over from my planking. First this needed to be cut to length., slightly shorter than the 56mm strips
The 5mm width is to wide so i cut down to 2 x 3 and then sanded the ends into shape. next I drew a line down the centre and marked 2mm in from the end and then every 4mm
Using a round nosed power tool I put a countersink into the strip at the points I had marked. that gave me space for 17 shot.
I finished the frame and glued the shot racks to the sides, a quick sand and then two coats of walnut brown.
To paint the shot I first scatted it on some masking tape and painted the shot as much as possible.
once dry each shot was given a dab of glue and put in place. when the glue has set you can touch up the top of the shot wit a quick lick of black paint. Job done!!BigGrin
Son of Bulwark
#2 Posted : 01 May 2011 14:50:00
Hi Jase! Cool
Well what can I say? SPOT ON MATE! Drool
I know that the magazine has the grates different I'm ok with that but the detail you are going for shows that you have seen the ship for real and are going for that look!
Nice Work Jase!
#3 Posted : 01 May 2011 18:15:12
Ruddy good work there jase, lovely job mate...that's one task I'm not looking forward to...me thinks I will be accidentally losing the tiny cannon balls when It comes to fitting them.
Blink LOL
#4 Posted : 01 May 2011 22:19:24
Nice job Jase like the idea IanLOL
This page was generated in 0.041 seconds.
