Rigging Query Options
Gan_Javi
#1 Posted : 02 May 2011 03:29:26
Hi guys,
I just saw the most amazing scratch build on a static Santa Maria. The modeler's attention to detail was so amazing. There was one thing that stood out. One thing that I can not manage AT ALL.
I just built model of the 1805 Swift pilot boat. My problem came at all the places in the rigging where you have to "rope a rope".
Let me explain:
For instance at the dead-eyes. Those extending up have the bigger brown rope around it, which in turn has a thin piece of the other rope wrapped around it. It does look rather nice, the effect. My problem is how do you get it to stay there? Do you make a small knot?
I just glued it (I can imagine the more experience modelers out there sighing or snickering Blushing ). It doesn't look terrible, but you can see that it was just glued to stay.
Does anybody have any advice for me on how to fix this, or make it look more proffesional?
Kind regards from a newbie builder,
Francois
Son of Bulwark
#2 Posted : 02 May 2011 10:44:31
Hi Shipmate! Cool
What you are talking about is a common whipping.
First make a loop of thread place it over the rope the long end is wrapped around the thick rope over the loop. When you have enough turns on the rope pass the long end which is much shorter now through the loop, then pull the short end to pull the loop under the turns when it is pulled right in trim the ends and that’s it one common whipping.
Hope this helps!
This page was generated in 0.866 seconds.
