Great work Mark  the base is really coming along  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thank you Phil, for you kind comments. I have done a little more to the duo, I wanted to at least get the lighting wired in the base. First, I had to glue and fix both droids onto the base using some small wooden dowels to hold them in place and make them a little more sturdy. I then used some 5 minute epoxy glue, and pushing the wiring through the base with the holes I drilled. Then pushing the dowels into the holes on the base. Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
As you have seen in my previous post, I was going to use a remote circuit board to operate both droids, but having had two of the broads fail on me, I decided to keep it simple as shown. Once I had connected the wiring and tested it, I then screwed together the circuitry casing. The second picture shows I have attached a plastic base to the underside, using plastic card. I will later cover this in a velvet material. Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Here, you can see I have added some more sand, now the droids are in place, around their feet. I used a pipette to carefully drop the sand in place before applying some glue to hold it all together. This will be allowed to dry, before painting as I did before. Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Superb work Mark, some excellent modelling tips too.... Regards Alan
 Top work and an excellent how too guide included, just cant get any better Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thank you Alan & Andy for you comments. Mark Regards Markwarren (Mark) Admin
All looking great Mark  really outstanding work  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Joined: 04/05/2011 Posts: 173 Points: 528 Location: Sussex
Thank you Phil and Lee for looking in and your kind words. Mark Regards Markwarren (Mark) Admin
Superb work as always!
Great work Mark, looking very impressive.
The diorama is now complete. I have also bought a display case to keep the dust off the duo. Here, you can see I painted the sand around their feet the same as I did last time. I have also fitted some velour to the base to make it look a bit more professional. Once this was done, I then airbrushed some black around the outer rim to blend in with the base. I also attached a metal name plate to finish off the model. Hope you enjoy the pictures, as much as I have enjoyed building these two, and thank you to all who have followed this build and all your contributions over the year.
Here is a link to the full size pictures. https://www.dropbox.com/...sl8fvTKLmpvIEYHWga?dl=0
Here is the YouTube video show the lights working. https://youtu.be/ogBObdtSS3w
Fantastic end result and thanks for sharing your “tricks”
 Rank: Pro        Groups: registriert
Joined: 13/03/2012 Posts: 306 Points: 847 Location: Germany
Hi Mark i love it, excellent work!!!!Forum Support Team http://www.model-space.com/de/
They look brilliant  really enjoyed your build Mark  outstanding work  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Top build Mark and a great result Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thank you all for the kind words and support. Mark Regards Markwarren (Mark) Admin
Simply stunning Mark and a true mark of your skills..... Regards Alan
 Rank: Semi-Pro Level 2 Groups: Registered
Joined: 08/05/2016 Posts: 79 Points: 251 Location: Perth, W.Australia
Hey Mark , Terrific looking duo you’ve got there  . Thanks for sharing your techniques and tips during this build . Congratulations , and good luck with the comp . Ged
