wood for lining the gun ports Options
cal
#1 Posted : 04 May 2011 20:11:10
hi everyone has anyone else come up short with the wood for lining the ports ive still got all the tops & quite a few of the bottoms of one side to do & only got about 5 inch left :(
jeff averre
#2 Posted : 04 May 2011 23:10:40
Sorry Cal, can't back you up there, I had plenty of material, generally there has been ample building materials from DeAg although occasionly I needed to be carefull because of wood quality!
JeffBigGrin
#3 Posted : 04 May 2011 23:16:48
Hi Cal De Ag have always supplied enough wood, and always good quality, better than Eaglemoss Endeavour, I am talking 3 builds over 14 months
Cheers
#4 Posted : 05 May 2011 09:13:52
If you checked the 1.5x4mm strip qty received against what is noted in the parts supply list, then you should have enough lining material to complete; not forgetting that issue 34 notes that the lining strip in 34 is enough to line the ports of just the starboard side and entry ports on both sides, issue 35 contains a further 8 strips for lining the port side gun ports and the two stern gun ports.
Is it possible you only have issue 34 and not tackled as per that noted?
cal
#5 Posted : 05 May 2011 10:04:18
cheers mr T just looked at issue 35 properly & found the other strips did look last night but thought they were all planks amzing what u find after some advice & some sleep Blushing
#6 Posted : 05 May 2011 10:18:39
Good stuff, all is well then Cool
This page was generated in 1.052 seconds.
