6 Pages 123>»
Artesania 1/16 Fokker Dr.1 Build Options
#1 Posted : 22 October 2017 21:59:32
This is where the build diary for the Fokker Dr.1 starts.
Today I spent most of the day making up mini assembly's for the cockpit, this included mould lines and burs on the castings so I now have several small assembly's ready for undercoating.
I then moved on to the fuselage build after a good clean up of the cast parts assembly commenced. The fuselage is split into three sub-assembly's. Cockpit, centre section and tail then there all joined up. The assembly of the above is quite fast using the brass tubes to join everything up and makes a very sturdy assembly. A final tidy up will be done and then the undercoat will go on.
More soon.
#2 Posted : 23 October 2017 07:18:39
Nice start Andy, that must have some weight to it.
#3 Posted : 23 October 2017 09:48:01
Looks to be a real great kit Andy BigGrin the quality you can tell from the pictures is top drawDrool Drool regards PhilCool
#4 Posted : 23 October 2017 18:24:04
Good start Andy BigGrin the fuselage frame takes shape quickly.
#5 Posted : 23 October 2017 18:57:37
BigGrin Thanks for looking in and your comments everyone.
I had a quick look at the Modelexpo Dr.1 kit the fuselage is built in a jig and brass tube used as the main fuselage longerons easy to get it wrong if your not carefull compared to the AL kits way of assembly its far easyer to put together.
Just an observation on how kit design has changed over the years the Modelexpo kit was designed years ago and the AL kit is the latest way to build tubular frame aircraft.Cool
#6 Posted : 23 October 2017 19:00:51
Looking very impressive already.
Keep it coming.
Roy.
#7 Posted : 23 October 2017 19:06:18
You've not wasted any time getting started with this Andy.
Looks great Cool
#8 Posted : 23 October 2017 19:14:09
Bit more done the prepared parts have now been undercoated along with the fuselage [ I noticed I missed a couple of places when editing the pics but all put right now].
Whilst waiting for the paint to dry I carried on constructing the tailplane this is all made from a heavy 1mm thick piece of steel etch. The stabiliser and fin is made from the above etch, two 1mm parts are glued together to make the main frame of the stabilizer and then ribs and the outer frame added,
The fin is made up from three 1mm parts and a cast pivot arm.
The elevator is made up from standard etch with a 2mm bamboo dowel used as the spine. As with the fuselage all went together with ease.
Lots of painting still to do will update soon.
#9 Posted : 23 October 2017 23:51:43
Nice start, all looking good....Cool Cool
#10 Posted : 24 October 2017 18:03:33
BigGrin Thanks for looking in and your comments AlanCool
#11 Posted : 24 October 2017 19:53:36
Your certainly cracking on with this Andy BigGrin its looking good.
#12 Posted : 25 October 2017 21:20:16
BigGrin Thanks for looking in Al and your commentsCool
#13 Posted : 25 October 2017 21:25:10
Started painting, everything that needed it has been undercoated and now the top coats start to go on. The fuselage and tailplane has been coated with Tamiya Cockpit green and a few other parts are shown in mid painting stage.
More soon.
#14 Posted : 25 October 2017 23:52:36
Looking good, nice work....Cool Cool
#15 Posted : 26 October 2017 11:43:33
Hi Andy.
great start to your build. look forward to seeing this one come together.
Ian Cool BigGrin
#16 Posted : 26 October 2017 13:33:43
Nice work Andy, certainly looks really sturdy.
#17 Posted : 26 October 2017 15:09:30
Looks well with some paint on BigGrin
#18 Posted : 26 October 2017 16:05:01
Looking great Andy BigGrin i think this might be blink and you miss it buildLOL LOL its been a real quick few updatesDrool Drool regards PhilCool
#19 Posted : 26 October 2017 21:47:43
BigGrin Thanks for looking in everyone and your commentsCool
#20 Posted : 27 October 2017 16:11:30
The paint and the Miniart Baron Richthofen kit has arrived today.
The paint i am using is Tamiya XF- 7 Flat Red and is a match for the RAL number given in the instructions.
The mini art kit comes in grey plastic with some nice details and you even get his dog, also included in the kit is a stand/plinth if you wish to use it.
More soon.
6 Pages 123>»
This page was generated in 0.216 seconds.
