106 Pages «<6970717273>»
Sticky Wickett
#1401 Posted : 26 October 2017 21:22:56
This week's update of my U230 U-boat build is all about the paint!
After many weeks of riveting it's now time to break out the spray gun and give this boat some colour.
Before i started I had to check fit some of the supports for the rudders so that I wouldn't have to mess about once the paint was on. This proved to be worthwhile when looking at the part-works instructions, two, 5mm holes had to be drilled to accept the locating pins for the rudders.
Once happy with this i made an area in the middle of my kitchen, sitting the boat on a small table, all covered with dust covers. By doing this i could walk around the boat, working on one area and then moving to the other side with easy access.
I chose to prime the boat in Vallejo white rather than grey primer as i felt the latter would prove difficult to define once I started putting colour on.
The attached photo shows the bow in primer. Spraying took a long time in all of the different stages due to the large surface area.
Sticky Wickett
#1402 Posted : 26 October 2017 21:27:04
Looking further aft. What you see is the result of several thin coats, building up an even finish. The different materials that make up the boat; plastic, brass, filler in places and glue, all had a different effect on the paint when keying it in.
Sticky Wickett
#1403 Posted : 26 October 2017 21:27:36
Stern in primer.
Sticky Wickett
#1404 Posted : 26 October 2017 21:28:14
From above.
Sticky Wickett
#1405 Posted : 26 October 2017 21:29:22
Close up of the bow in primer.
Sticky Wickett
#1406 Posted : 26 October 2017 21:48:48
Once i was happy with the priming stage, it was now time to start applying some colour.
After a bit of research on the different paints used on U-boats and more research to see what paints were out there, i purchased two paint sets by Life Colour; German Navy WWII set one and two.
I found out that U-boats during the War were, generally, painted in Dunkelgrau 51 [medium grey] and Hellgrau 50 [light grey] above the waterline and Dunkelgrau 52 [dark grey], below.
These three shades of grey were covered by the two sets; two colours from set one and the other from set two.
I started with the medium grey as this is the dominant colour above the waterline. I didn't mask off any areas at this stage, just made sure I sprayed the paint well below were the dark grey would start.
Sticky Wickett
#1407 Posted : 26 October 2017 21:49:27
Continuing aft with the medium grey.
Sticky Wickett
#1408 Posted : 26 October 2017 21:50:22
Moving further aft.
Sticky Wickett
#1409 Posted : 26 October 2017 21:51:56
Medium grey completed, looking at the port side.
Sticky Wickett
#1410 Posted : 26 October 2017 21:52:23
Looking at the starboard side. I then sprayed over the medium grey with matt varnish to seal the paint and prevent 'lift' when masking.
Sticky Wickett
#1411 Posted : 26 October 2017 21:57:54
One of the reasons i like the look of U230 in the later stages of it's short life is that it sported light grey, camouflage stripes.
I used Hellgrau 50 [light grey] for the camouflage after studying a photograph of the real boat in La Spezia in 1943 and reading Dougie Martindale's article on U-boat paints.
This photo shows the areas to be painted, masked off.
Sticky Wickett
#1412 Posted : 26 October 2017 22:01:19
Masking off from above.
#1413 Posted : 26 October 2017 22:01:29
That just looks so good now all the parts are blended in with some paint.
And all that rivet detail you added was well worth the extra work as it adds another level of outstanding detail to your model.
Sticky Wickett
#1414 Posted : 26 October 2017 22:10:13
Thank you Tony!Cool I made sure i added thinners to the paint to prevent losing the rivet detail. There were a couple of moments after finishing a coat when I thought 'I can't see any rivets', realising all those weeks of work were in vain, only for the paint to dry and they all reappeared! <sigh of relief>BigGrin
Phil W.
Sticky Wickett
#1415 Posted : 26 October 2017 22:12:41
Masking tape removed to reveal the rear of the camouflage stripes in light grey. I didn't mask off the top deck to make sure I applied an even coat to the edge of the casing.
Sticky Wickett
#1416 Posted : 26 October 2017 22:13:36
This photo shows the mid-camouflage stripe.
Sticky Wickett
#1417 Posted : 26 October 2017 22:15:21
Camouflage pattern on the starboard bow. I based the shapes and sizes of these camouflage stripes on a photo of U230 in La Spezia in 1943.
Sticky Wickett
#1418 Posted : 26 October 2017 22:18:36
Once I had removed all of the masking tape I sprayed matt varnish over these areas to seal the paint.
Next step was to mark out the dividing line betwween the medium grey and dark grey. The dark grey covers the majority of the boat.
I clamped a pencil to an engineers square to use as a marking out tool. This photo shows the dividing line being marked out.
Sticky Wickett
#1419 Posted : 26 October 2017 22:19:17
Masking up the stern, following the guide line.
Sticky Wickett
#1420 Posted : 26 October 2017 22:19:57
Masking up the amidships section.
Guest (27)
This page was generated in 0.477 seconds.
