6 Pages «<3456>
Al's MP4/4 build Options
#81 Posted : 27 October 2017 13:52:59
Thanks Alan BigGrin these large scale cars are great but they do take up some spaceLOL
maurizio67
#82 Posted : 29 October 2017 22:22:47
you are right, they are really great scales to find their placeBigGrin
RM1
#83 Posted : 30 October 2017 07:50:05
Coming along nicely, Al.
Keep up the good work.
Malc.
#84 Posted : 19 November 2017 17:03:58
Thanks Malc BigGrin
#85 Posted : 19 November 2017 17:17:35
Pack 15
This pack is mainly adding parts to the engine and also some brake pipes and a couple of hoses.
Thanks for looking.
#86 Posted : 24 December 2017 00:52:46
pack 16
Starting to add some of the larger sub assemblies to the monocoque. Have added the front brake ducts, ty-wraps on front and rear brake lines, the pop off valve, radiator housings, the injectors and fuel pipes.
Thanks for looking
maurizio67
#87 Posted : 25 December 2017 14:38:55
Spal wrote:
pack 16
Thanks for looking
buon natale spal
#88 Posted : 25 December 2017 17:44:47
Thanks Maurizio BigGrin Merry Christmas.
#89 Posted : 21 January 2018 17:13:15
Pack 17
In this pack both turbos are built and fuel pipes added followed by attaching the fuel pump and header tank hose to the engine block.The left and right wastegates are assembled and the oil/water heat exchanger has been attached to the engine block. The check valve and the water inlet pump pipe are added to the header tank and the throttle sensors and oil filter joints to the plenum chamber.
Thanks for looking
#90 Posted : 21 January 2018 21:20:53
BigGrin Looking good AlCool
#91 Posted : 30 January 2018 14:45:45
Thanks Andy BigGrin
#92 Posted : 24 February 2018 00:15:08
Pack 18
In this stage the header tank and plenum chamber are fitted, followed by the nosecone. After the fitting of the two intercooler to engine pipes the engine is temporarily fitted onto the rear of the monocoque by its mounting plates.
Pipework is added to the turbocharger and wastegate assemblies before the underbody is fitted and the turbochargers then added. The rear underbody is then used to correctly position the exhaust pipes while the glue cures. Once this was done the turbo air intakes had pipes fitted and temporarily fitted in position. These were then removed as was both underbody panels and the engine block. Four hoses were then attached to the block and turbos.
Thanks for looking
#93 Posted : 24 February 2018 12:24:33
Nice work Al, it does look impressive.
TRGRichie
#94 Posted : 24 February 2018 21:54:03
This kit is on my wish list, and seeing your build is making me want it even more. Great work.
Rich
AUTO FRUMP STOMPER
#95 Posted : 25 February 2018 00:09:13
Thanks for looking in guys BigGrin Its a great kit Rich treat yourself.
#96 Posted : 28 April 2018 22:15:29
Pack 19
The penultimate set of parts has arrived.In this pack we assemble the seat harness and add the fuel filler neck before adding a couple of stickers to the steering wheel. This was followed by attaching the battery cable and several wires to the CDI unit,telemetry unit and electrical system. The final part of this pack was the fitting of various switches to the instrument panel followed by the data and rev counter display.
RM1
#97 Posted : 29 April 2018 10:41:59
That's looking great. Nearly complete!!
Malc.
#98 Posted : 29 April 2018 11:07:14
Lovely work Al, looking stunning.Love Drool
#99 Posted : 29 April 2018 16:01:24
Nice work Al, looking good as you go into the last few laps - well done! Cool ThumpUp
#100 Posted : 29 April 2018 18:17:56
BigGrin Looking good Al and nice workCool
6 Pages «<3456>
This page was generated in 0.116 seconds.
