9 Pages «<45678>»
Micks aka Mogwai C57 build diary Options
#101 Posted : 28 October 2017 17:37:14
PACK 7
Stage 53
The running board 6
Here we attach the running board to the right hand side at the rear. Attach another oil pump box,and the boiler tank. Then glue the fire hydrant to the water supply pipe. Then glue this in the water pump.in hole and to the water pump body itself.cheers mick.BigGrin
#102 Posted : 28 October 2017 17:43:12
PACK 7
Stage 54
The cab 1
Here we put the connecter on the headlamp wires. Then attach a small bracket to the cab. Then screw the cab to the train itself.cheers mick.BigGrin
#103 Posted : 28 October 2017 17:52:20
mogwai wrote:
PACK 6
Stage 43
Hi all bin a while,I had to pull out of this one due to sickness and lack of money.but I'm back with it now. Cs allowed me to buy the remaining packs in one go.so big thankyou to them. mick. BigGrin
Hi Mick, BigGrin BigGrin
So good to see you back on this one and really hope you are feeling much better.
Looks like you`re well and truly back up to speed and I look forward to seeing your future updates. Cool Cool
#104 Posted : 28 October 2017 17:55:27
PACK 7
Stage 55
The cab 2
Here we screw the floor together pay attention here and don't screw the floor on upside down.then insert the floor and put in all the necessary screws.you may need to loosen the 4 screws on top of the boiler to get it to sit neatly against running boards.the cab sides glue to brackets fixed to floor by screws.then it's fit the white trim places. This concludes pack 7.cheers mick.BigGrin
#105 Posted : 28 October 2017 18:17:12
BigGrin Looking good MickCool
#106 Posted : 28 October 2017 23:09:29
Lovely work Mick and great to see you back with us.... Look forward to seeing this one progress further.....Cool Cool
#107 Posted : 29 October 2017 10:03:03
Nice work Mick, coming on very nicely.BigGrin
#108 Posted : 29 October 2017 13:17:29
Nice to see you get back on this Mick BigGrin looking great.
#109 Posted : 29 October 2017 22:36:24
Mick
So pleased to hear you have been able to get back to this one as it would have been a shame after having started it.
I very much like the pre-finished paintwork on this kit.
Hoping the rest of your build goes well.
#110 Posted : 30 October 2017 17:15:44
PACK 8
Stage 56
The cab 3
First of all thanks to everyone who looked in and left comments much appreciated. So the start of pack 8 here we glue the seats to there bases, and fix them inside cab.add the brake valve to the floor and put pipe in from water ejector through the hole in floor. Cheers mick BigGrin
#111 Posted : 30 October 2017 17:22:49
I can see your well into this one again.
Like the green seats as its adds a little eye catching detailo the overall black finish.
Hope it all continues well.
#112 Posted : 30 October 2017 17:25:34
PACK 8
The cab 4 and 5
Stages 57 and 58
I put the two stages together as they are exactly the same just opposite sides.here we screw on 2 little brackets to the side wall to take the cab top bits. Glue the side window frame to the outside of cab.put the sliding window in frame and glue this to the inside, then glue the window eave in. Cheers mick. BigGrin
#113 Posted : 30 October 2017 17:33:32
PACK 8
Stage 59
The cab 6
Here we glue the doors to the front of the cab.glue the window eaves in over these.glue the rear window frames on, and glue in the 2 roof beams. Cheers mick. BigGrin
#114 Posted : 30 October 2017 17:42:36
PACK 8
Stage 60
The cab 7
Here we first screw in the seat backs.glue in the air cooling tube from stage 49, and the control valve rod from stage 36.glue the skylight onto the roof.and glue the cab rear piece onto the roof. Cheers mick BigGrin
#115 Posted : 30 October 2017 17:57:22
PACK 8
Stage 61
The cab 8
Here we screw on the left and right cab end beams. Place the body on the chassis and screw it on via 4 screw at the back. Then we put the brackets onto the gutter pipes.and fit these to the rear of the cab.had to file my holes a little as brackets were to big to go in.i decided to fit the brackets that hold the end of the pipes before I glued the brackets to the cab just to make sure all aligned. The left hand bracket screws into the distribution valve.and the right uses nuts and bolts to fit it.this is as far as got now as you can see by tape holding all in place till glue sets. More soon cheers mick.BigGrin
#116 Posted : 30 October 2017 19:18:59
Really good job with this Mick, looks great Cool
#117 Posted : 30 October 2017 22:00:17
Great job Mick Cool looking impressive mounted on the chassis.
#118 Posted : 30 October 2017 23:58:42
Very nice update, all looking first class Mick and a joy to see.....Cool Cool
#119 Posted : 01 November 2017 17:11:45
PACK 8
Stage 62
The cab 9
Hi thanks to all who looked in and left comments much appreciated. Here we glue in the few bits to the roof top. Then assemble the 3 parts to the 3 way valve attach this to bottom of cab floor. Put the cooling tube in from stage 51 from the 3 way valve to the water pump, then glue the pressure regulator to this pipe.cheers mick.BigGrin
#120 Posted : 01 November 2017 17:14:33
9 Pages «<45678>»
This page was generated in 0.415 seconds.
