Advice needed Options
comic123
#1 Posted : 06 May 2011 22:09:36
I will be painting my Victory, what is the best way to stain/colour the decks. Have tried a med oak spirit stain but wood comes up nothing like the colour chart withthe stainBored Bored
Anyone help out a noviceBored
jeff averre
#2 Posted : 06 May 2011 22:38:15
Hi Comic,
I've come accross this problem and wasted ££'s on stain that is totally different to 'what it say's on the tin'. I'm afraid its a case of trial & error, I've even tried tea and coffee as stain, believe it or not 'pine' stain is more like light oak than 'light oak'. You can try mixing and watering down to get the right tone, but allways try out on spare wood!
good luck,
Jeff
benny
#3 Posted : 06 May 2011 23:45:49
hi comic..i work in this industry as jase said its trial an error.....firstly to get a good stain on ur deck or piece of wood it needs to be clean,clean it by sanding it with 120 grade wet and dry paper or fine wire wool with a drop of white spirit then apply a thin coat of oil mixed 40% oil 60% spirit with a cloth u can then see if the surface is clean but after 30 seconds go over it with another cloth to dry it,it will still take a stain.. if u choose a stain which is too dark u can lighten it with a spot of white spirit on a fine piece of wire wool and rub it evenly on the decking or you can lighten it first by mixing it with danish or teak oil if its to light add more stain if its too dark add more oil...when you finally have your chosen colour leave to dry then apply 2 coats of neat oil but remember to rag the oil off after 30 secs or so,leave to dry then seal with clear varnish...hope this helps
cheers benny
This page was generated in 2.933 seconds.
